Quadrafire CB1200 not starting - Control Box Amber light Blinks 3 times not feeding pellets
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by don2222, Oct 1, 2016.
  1. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Lousyweather and imacman like this.
  2. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    I bought a couple of those Thermocouples.
    Yes....THE POLARITY IS AZZ BACKWARDS......Red and yellow are reversed.....
    The computer does not get the signal it is looking for.....Swap the wires and all is well.
    jtakeman likes this.
  3. StEarl
    StEarl
    millinocket, maine
    Well, part came in today.
    Basically their red wire is my yellow wire, and vice versa.
    Really super ******* unhappy with these people.
    But the stove is running.
    Thanks for the help everyone.
  4. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Spend the big $$$$ and get the factory part and the colors will be as they were when the stove was made.
    I had to sort this crap out with my VOM to finally see WTF was wrong.....Swap the wires and ALL WAS GOOD.
    The difference in price was OK.....Sure would have been better if the wires were colored correctly.
    IIRC It was that the wires are different materials and the color of the jacket as mated with the wire material is backwards......
    Glad you are running...
  5. slvrblkk
    slvrblkk
    Northampton, PA
    Absolutely ridiculous that these are still in the market. Glad your stove is working though.
    SmokeyTheBear and imacman like this.
  6. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    New old stock will get you every time, now for real enjoyment watch a gimp use a drill and soldering iron, my parts are here maybe I can build some electrical filters I am tired of the hiss. Makes tuning a SDR painful.
    imacman and slvrblkk like this.
  7. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Let us see what happens moving antenna away from the system does
    Screenshot from 2023-03-22 14-31-49.png :
    Blithering Idiot likes this.
  8. Scot Linkletter
    Scot Linkletter
    Athens, ME
    Your original had a red and yellow wire and the replacement had a red and white wire? Is it working OK?
    Normally, red and yellow wire signifies a K type thermocouple which can read a temperature from -454 to 2300°F.
    Red and white signifies a J type thermocouple which reads from -346 to 1400°F.
    Both are very common but the J type has a shorter life span at high temperatures than the K type - and the device reading the temperature needs to be set to the correct type.
    imacman and don2222 like this.
