Had to Buy Diamond Files to Sharpen? WTH?
Discussion in 'Chainsaws and Power Equipment' started by buZZsaw BRAD, Jan 6, 2023.
  1. Eggshooterist
    Eggshooterist
    Erff
    That's not scientific enough. Do better Mr. Lol
  2. buZZsaw BRAD
    :rofl: :lol: any suggestions?
  3. Eggshooterist
    Eggshooterist
    Erff
    Cut wood, dull chains, sharpen. Several.
  4. Mrxlh
    Mrxlh
    Dat Boot
    Must be the grinding process, I found 4 work hardened teeth on a brand new chain I had to re sharpen on Sunday. I guess I need some of the circular grinding stones to fix them. I know it’s work hardened as I was able to file under one of the hard spots on 1 cutter.
  5. Mrxlh
    Mrxlh
    Dat Boot
    Oregon 72EXL…
  6. chris
    work hardening of the chain teeth is something that happens , compounded by the chrome plating with Stilh chains being the worst in this case as they have a heaver chrome coat on them. Chrome is harder than most files. keeping chips from sticking in the file - the old go to method was to coat the file with chalk and of course a little bit of time with a file card every so often to remove any chips that do stick. Files only cut in one direction for the most , dragging them back with pressure just dulls them very quickly.
  7. isaaccarlson
    isaaccarlson
    Colfax, WI
    Yep, there was a guy who dragged a file backwards several thousand times and said it was fine, as a test, but that was not on chrome cutters.
    T.Jeff Veal likes this.
  8. The Wood Wolverine
    Then you have aXXhats like this:
    :rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol:
  9. isaaccarlson
    isaaccarlson
    Colfax, WI
    What the heck was that?!
  10. buzz-saw
    buzz-saw
    Ct.
  11. Mrxlh
    Mrxlh
    Dat Boot
    Purchased the cheap dremel 3 pack chain grinding stones in the 3 different diameters. Chucked up in my drill on high works like a charm, just hit it for a couple seconds and viola, the hard spot is gone… 6C9DBF78-2703-4C2B-9CA8-72B5516F1CA9.jpeg
  12. buZZsaw BRAD
    I have some grinding stones that ive used in my cordless drill. Have to remember to give that a shot. The diamond files did the trick though.
  13. MasterMech
    10 minutes of your life that you're never getting back.
