Are the newer style gasification boilers less troublesome?
Discussion in 'OWB's and Gasification Boilers' started by Lehman, Jan 18, 2023.
  1. Farmchuck
    Farmchuck
    Nepa
    Same principles of operation though.:handshake:
    brenndatomu likes this.
  2. Farmchuck
    Farmchuck
    Nepa
    Thanks for all the information everyone. I’m going to pull the fan tomorrow & see what I find. Also going to let my dealer know what’s going on in case it is a warranty issue.
  3. Farmchuck
    Farmchuck
    Nepa
    So I just got ready to go to bed & my wife closed the shade in our bedroom window & said” honey the red light is flashing on the wood stove “ so I went over & sure enough the fan breaker was tripped. So I figured I may as well take the blower motor off & see what I find. image.jpg
  4. Farmchuck
    Farmchuck
    Nepa
  5. Farmchuck
    Farmchuck
    Nepa
    Any ideas on the best way to remove this crud? Wire brush?
  6. brenndatomu
    That would be my first choice I think...that and a putty knife, or some sort of scraper.
    Might could carefully apply some heat to it to get things dried out and easier to remove...creosote will kinda puff up when heated up...easier to remove then. Looks like maybe it just needs cleaned up all around the edge there...where the impellor is almost touching the fan housing...or is the buildup hitting somewhere inside the housing when mounted up in normal operation?
  7. Farmchuck
    Farmchuck
    Nepa
    I got the impeller off. And scraped all around the motor side in the back of the impeller. It’s all pretty crudded up but it’s dry creosote. A lot is coming off the brush I just sprayed some WD-40 on the spot to see if that loosens it.
  8. brenndatomu
    I'm surprised that it's that crudded up...my understanding is that things usually dry out/clean up when it gets cold (like its been the last day or so) out and the boiler gets a chance to stretch its legs a lil...
    Farmchuck likes this.
  9. Farmchuck
    Farmchuck
    Nepa
    Got it back together & it’s running. We’ll see what we have in the morning.
  10. Farmchuck
    Farmchuck
    Nepa
    Somewhat cleaner: 63EAEA2B-D8AD-4086-8D9F-5AB71787AA3D.jpeg 4382C4E4-1371-4A13-86F4-C4DC17647ADD.jpeg 9D840D03-62E6-4840-B2D9-93980D75E5C6.jpeg CCE5CA0C-A65E-4CBB-9BEA-A1C42A620A58.jpeg 7C39CF85-5442-4F3E-AA38-C2DA4C2F52A4.jpeg 91BAA8F5-32F8-4EB7-A276-61DC3AA2AB49.jpeg
  11. Creekin
    Creekin
    Manitoba
    I've had that happen to me before with the fan, what sucks about mine is that it has glass fuses instead of circuit breakers
    Its usually after a bit of a warm spell, and the boiler ends up idling more
    Nice thing is that it comes out easy
    I've used a hacksaw blade to clean between the impeller and the housing
    Farmchuck and brenndatomu like this.
  12. Farmchuck
    Farmchuck
    Nepa
    Thanks for the tip!:)
  13. Farmchuck
    Farmchuck
    Nepa
    Just finished chores & checked the fire. Everything working as it should. Guess I’ll try splitting the wood I have into smaller splits. I can’t think of. Morningwood mentioned leaving the bypass open to long possibly being any issue. I could be guilty of that as well. We shall see. Thanks for all the help fellas.
  14. lukem
    Looks like the impeller most likely got stuck by the looks of that build up. I get some buildup of dry powdery ash on mine that I clean off once a year.
    Only had the creosote problem once during some mild weather when I was burning wood that wasn't nearly dry enough.
  15. morningwood
    morningwood Administrator
    This was / is a problem on the older G series. On the boilers we have you can only have the bypass lever for a maximum of 5 minutes and then the fan kicks off. I took my fan off a month or so ago, it had a layer of fine ash on it. The HM gurus recommend cleaning it at least once a winter and at the end of the year. My plan is clean mine as often as I can since it's not a very hard job.
    I took the plate off of the back and vacuumed out above the turbulators too. That was probably a waste of time but I figured I'd do it while I had the tools out there.
  16. Farmchuck
    Farmchuck
    Nepa
    Thanks for the information. It is much appreciated. I still have a lot to learn.
    brenndatomu and morningwood like this.
  17. Farmchuck
    Farmchuck
    Nepa
    I was surprised that the material on the impellers was enough to keep the fan from turning.
  18. morningwood
    That's one thing that I really liked about the Polar over the HM. The Polar has a really nice ECM fan ( high dollar too ) on it. The Polar was also 3k or 4k more when I looked it too.
    Maybe keep an eye on your runtime ( it's on the PLC ) and make sure you clean the fan every X hundred hours. Mine had roughly 400 - 500 hours on it when I cleaned it. I'm close to 700 now.
    brenndatomu and Farmchuck like this.
