Are the newer style gasification boilers less troublesome?
Discussion in 'OWB's and Gasification Boilers' started by Lehman, Jan 18, 2023.
  1. morningwood
    morningwood
    I thought about putting a UPS in the back of my boiler cabinet. On a G4000 there just isn't enough room to put one that can run everything for more than a few minutes. I'm not sure how the batteries would do in the cold ( <40F ) too.
    Farmchuck and brenndatomu like this.
  2. brenndatomu
    Should be ok...probably doesn't get that cold in there with everything that is going on there (unless you did a really good job of insulating)
    I have some UPS units in unheated outdoor control panels at work...no issues, not a huge load on them though either.
    Farmchuck and morningwood like this.
  3. jrider
    jrider
    I took a before and after pic of loading this afternoon. Didn’t rake any ashes and filled it up with my usual ugly chunks of all shapes and sizes. Closed the door and done. Not saying this to brag, just showing that nothing special is needed for my unit.
  4. morningwood
    morningwood
    How are pieces that are large gassing enough for your boiler to function properly ? The more surface area you have for the wood to be charred on the more wood gas you make.
    brenndatomu and Farmchuck like this.
  5. jrider
    jrider
    I don't know. Let me start by saying this is the only owb I've owned. I went with a gasification unit because I live on 1.5 acres in a neighborhood where we all have similar sized lots. I was afraid of smoking my neighbors out and having them complain if I got a conventional unit. I was sold on the term "virtually smokeless" and it has lived up to that description. I bought it to get rid of junk wood that I can't sell. I had read that these could be finicky/not run properly with wood that wasn't split somewhat uniformly or with wood that was too big. I slowly introduced more odd ball and bigger chunks and realized, if I can fit it through the door (and pack small pieces around it) it will burn it with no problems. This is the 11th winter with this unit and I do bare minimum cleaning/maintenance (moving coals around, carefully positioning logs, etc.) and it just chugs along with most of my neighbors having no clue that it's burning wood to heat my house. Portage and Main has zero complaints from me!
  6. jrider
    jrider
    Just a picture I took this morning before loading it. Thats what was left from the previous picture I posted
    Barcroftb, Farmchuck and brenndatomu like this.
  7. Lehman
    Lehman
    Minnesota
    Well the smallest wood master is the clean fire 300
    That they rate at 150000 btu boiler is 11,000. Next one up is the clean fire 500 at 200,000 btu hours. The 500 is about 3000$ more and I’m sure one of these 2 will heat what I need. 2300 sq ft house with 2x6 walls and 24” of fiberglass in attic and a 900 sq ft shop insulated 2x4 walls all the way around and 12-16” fiberglass in ceiling. The shop is basically half the whole garage with 10 ft walls and a flat insulated roof built inside the main peaked roof of metal garage
  8. morningwood
    morningwood
    I'd go for the smaller boiler if it was me. Mine is rated at less max BTU and they say it will heat 4k of well insulated space. I'm heating 3k ( 2.200 sq ft house + 800 sq ft basement ) and it doesn't even struggle. My house has is very similarly insulated to yours.
    Farmchuck likes this.
  9. brenndatomu
    Agreed...the gassers run better when they have load...so going "too big" is not an advantage
    Farmchuck and Lehman like this.
  10. Lehman
    Lehman
    Minnesota
    was looking for used ones in the area and another wood master dealer had a approximate sizing chart now I’m more confused. Basically according to the chart i should have a 500/700
  11. brenndatomu
    I hate those "sq footage" sizing charts...misleading...they even admit it in their disclaimers!
    What do you heat with now? Do you have heating bills from recent winters where the place was heated totally with "fossil fuel"? If so, then you can come up with a realistic BTU load...
  12. Lehman
    Lehman
    Minnesota
    It’s a propane boiler in house Weil McLain CGA gold so the older less efficient style boiler. Go through 2 500 gallon tanks a year roughly. Garage is a forced air 45,000 btu heater 2 250 gallon tanks a year there usually.
  13. Lehman
    Lehman
    Minnesota
    I have the cga 3 or 4 pretty sure it’s the 4
  14. brenndatomu
    Is that a hanging "unit heater"? (typical garage heater) probably 80% efficient if so...need the efficiency rating to calculate BTU's "used" by the building...
  15. brenndatomu
    So it appears that your house is using about 76,861,680 BTU's per year (propane is 91,502 BTU's/gallon...x 1000 gallons....x .84 (% efficiency) =76,861,680 BTU's to the house) Unless you have all gas appliances, then some of that is going to them too...but probably not a ton...most of the "heavy use" would be taken up by the OWB, as long as you tie in for your DHW too...
    How long would you say your heating season is...from when the heat often starts running (more than once/twice per day) to when its basically over? (on average)
  16. Lehman
    Lehman
    Minnesota
    45,000 btu heater in shop. Heating season varies usually October to may ob average
  17. Lehman
    Lehman
    Minnesota
    500 gallon tank only holds about 400 gallons in actual use. They fill to about 80% only
  18. morningwood
    morningwood
    When looking at the ratings make sure you make your buying decision on size is based off of the steady state BTU's / 8 hour burn rate the boiler provides. A G4000 can max out at around 100k but the steady state is 68k. My toaster bank on my geo is 55k BTU so I knew I'd be good with the boiler that provided the 68k steady state.
    This is for temps <10F or 0F in my case.
  19. Lehman
    Lehman
    Minnesota
    33B4CF47-AF25-4E34-AD12-CA2F6C052457.png CDE048E0-77A1-4F37-83D0-0CA2DD68183F.png
    the clean burn 300 & 500 ratings
  20. lukem
    I'm heating 1800 house, 1800 sq basement (lightly insulated), 500 sq garage to 60*. Even down to 0 my boiler doesn't even get challenged. I'm going to hook a 1000 sq ft shop up soon, but even then it won't be pushed anywhere near capacity. Here are the specs on it:
    5,000sq.
    Max burn 232,000/hr
    8 hour burn 112,000 BTU/hr
    Water 195 gallons
    Firebox 28 x 30 x 36
