Englander 25-PDVC pellet feed issues
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by edhackem, Jan 12, 2023.
  1. edhackem
    edhackem
    Pittsburgh PA
    My stove is having issues with keeping a steady supply of pellets entering the burn plate. All systems seem to be in operating order--augers rotate as they should. I replaced both motors on 12/1 and until the past few days they worked perfectly. When it does stop feeding, if I take the upper motor and wiggle it and poke the pellet feed entry in the hopper the supply restarts. And 15-20 mins or so it does it again. One thing I noticed when I did a reset the 3rd lower button wouldn't work. I could get the numbers to change on the 1st & 2nd, but the 3rd doesn't respond. Any suggestions?
    IHATEPROPANE and imacman like this.
  2. corncob
    corncob
    Somewhere in Lower Michigan
    No clue other than it's binding. I had one years ago and sold it. Usually, a non responsive board means a component failure
    IHATEPROPANE likes this.
  3. edhackem
    edhackem
    Pittsburgh PA
    wondering if it's possible the pellets are hanging up in the hopper near the entry area. It seems like when I run a long screwdriver in there that it will feed for a short period of time. Other then that it seems fine.
  4. jtakeman
    I'd say auger motor is one its last legs. Likely dry on the inside. I've heard of some adding a grease port and greasing them. I've only had luck with a disassembly/clean/relube.
    Also check you auger bushing for wear or bind.
    IHATEPROPANE, imacman and corncob like this.
  5. edhackem
    edhackem
    Pittsburgh PA
    found out from Mike at Englander support that there's a restrict or plate at the bottom of the feed hopper. Removed it and it seems to be cycling as it should. Also tightened up the set screws on both auger motors. yay
    PelletHound, IHATEPROPANE and imacman like this.
  6. corncob
    corncob
    Drive motors need lubed regularly. Fact of life. Mine get taken apart and lubed every spring.
  7. jtakeman
    Good to hear Mike is still there.
  8. Dok440
    Dok440
    NorCal
    When I bought my Englander pellet stove I also bought Golden Fire pellets. It was a disaster. It would clog and clog and clog again. I switched to Green Mountain and haven't had a clog since. It could be your stove just doesn't like a particular brand.
