“It’s dead Jim”
Discussion in 'The Wood Pile' started by Timberdog, Nov 15, 2022.
  1. jo191145
    I’m still wondering how the bar oil leaked out? Did it melt the cases?
  2. huskihl
    huskihl
    271/291 are the same saw different bore. No aftermarket cylinders available. I’m guessing the seals are good since it’s a newer model. Either it had old gas in it or it was tuned too lean and finally gave up the ghost when the weather cooled down
  3. Timberdog
    Timberdog
    Az
    Do I need to remove the clutch and sprocket to get the cylinder to separate from the crankcase anyone?
  4. jo191145
    Not a mechanic but if the piston is seized solid at top of stroke that would cause problems I imagine. Does it move?
    Horkn likes this.
  5. Horkn
    Even thinking of burning pine burned your saw up. :zip:
    That's too bad about the saw. Hopefully you can repair it without too much hassle.
  6. The Wood Wolverine
    I don't know Steals but there isn't a Husky I know of that needs the clutch removed to pull the cylinder. Should have 4 screws holding it down and it should pull up. Carb/intake, muffler and everything else in the way needs to be removed, obviously.
    buZZsaw BRAD, Sandhillbilly and Horkn like this.
  7. Timberdog
    Timberdog
    Az
    Yes
    Horkn and jo191145 like this.
  8. Timberdog
    Timberdog
    Az
    Horkn likes this.
  9. Timberdog
    Timberdog
    Az
    Yeah, thats what I thought. Did all that. Got the four bolts removed but it’s not coming apart. I’ll have to take another run at it after I get some time after Christmas. I hope it didn’t do something horrible like weld together…
    Horkn likes this.
  10. huskihl
    huskihl
    I haven’t worked on a 1 series clammy. But on the 029s and 390’s stuff, the rear bar stud threads into the engine pan
    Timberdog, Horkn and Mag Craft like this.
  11. Mag Craft
    Yes take the clutch and sprocket off. It will make it much easier to get the cylinder and the crank out.
    Timberdog and Horkn like this.
  12. The Wood Wolverine
    Definitely take the clutch off if removing the crank, that's a no brainer. Looking for some help, appears to me that you don't need to do all that to just lift the cylinder.
    You could just be fighting sealant.
  13. The Wood Wolverine
    Started @ 8:40 to show cylinder coming off. I don't know about this guys methods/advice. Just wanted to show that part of disassembly.
  14. Reloader
    Reloader
    NW Oregon
    I had a bar sprocket get jammed with junk and my saw acted like that. Saw got hot then also.
  15. Horkn
    I had that happen too, but did you see his piston pics through the exhaust port? Mine was literally just a bar tip sprocket jam as well as yours. This one is a bit more drastic.
  16. Mag Craft
    You need to pull the crank out because you will most likely replace the piston. Also, you can replace the cranks seals at the same time.
    Taking it, all apart will make it much easier to clean up. Make sure you use sealant that is fuel proof like yamabond.
    Cash Larue, Timberdog and Horkn like this.
  17. Elm-er Fudd
    Elm-er Fudd
    Kansas
    Not sure if the same kit works on the 1 series saws, but bailey’s sells replacement engines for the 029, 290, & 390. You can drop the 390 engine in the 290, same chassis…decent power upgrade for the same money.
  18. Timberdog
    Timberdog
    Az
    Finally got it apart. Piston and/or rings had a firm grip on the cylinder wall but got it off. Lookin pretty bad. Can the cylinder be saved?
    Ohio and Cash Larue like this.
  19. Timberdog
    Timberdog
    Az
    Are the 290 and 291 the same chassis?
  20. Mag Craft
    Never worked on a 291 only on a 290.
