Instead of a new trailer
Discussion in 'The DIY Room' started by Sirchopsalot, Apr 19, 2021.
  1. T.Jeff Veal
    Great idea...
    Horkn likes this.
  2. Sirchopsalot
    Sirchopsalot
    medium city in CT
    Offset is a good idea.
    Except that the sides go up beyond the top rail by a couple inches. It the 2x4 ended short of the top of the sides (under the rail), the top board would be somewhat unsupported.
    I really thought about height. Its 17.25", enough to stack 18" of wood just over the top. The option is there to add another layer of 1x6. I got tired of digging down 24" from the outside. I guess we"ll see how loading T.Jeff Veal style really works. Or another layer of rail can go on so we can just chuck wood in there.
    T.Jeff Veal and Horkn like this.
  3. eatonpcat
    Yep, I bolted thru the cross channels on mine.
    Horkn, Softwood and T.Jeff Veal like this.
  4. Sirchopsalot
    Sirchopsalot
    medium city in CT
    The boy (is back home, this dad's heart is complete) helped pull the screws drill holes, and I installed 1/4" carriage bolts with washers & lock washers. Didn't use lock nuts. I didnt get into the cross members....just the decking.
    Sca
    Horkn, T.Jeff Veal, eatonpcat and 2 others like this.
  5. eatonpcat
    Awesome!
    Horkn, T.Jeff Veal and Sirchopsalot like this.
  6. Sirchopsalot
    Sirchopsalot
    medium city in CT
    So the spare tire thingy from harbor fright was $40 ish, from TSC closer to $70.
    I met a fellow at Lowes who gave me this idea: a $9 u-bolt from TSC.
    I set it around a vertical member of the trailer, and on it went.
    Its as low as it would slide down the vertical support.
    I have lock washers to add on later.
    A 3/4" socket and ratchet now live in the truck for removing the tire....
    It's low enough not to interfere with loading too much.
    I suppose a cover of some sort might be a good idea.
    The first load with it there, I will check the height from ground. It could be raised rather easily.
    Horkn, MikeInMa, Softwood and 3 others like this.
  7. T.Jeff Veal
    Looks good. Yes, you could rotate the tire and have 1 hole below the clamp would also raise it a bit.
    Horkn, Sirchopsalot and brenndatomu like this.
  8. Sirchopsalot
    Sirchopsalot
    medium city in CT
    No kiddding.
    Wish I'd seen that!
    It looks like there is 6" ish of space. Thats a little skinny esp for pasture type places. Its rubber on metal, so i kinda think I could loosen it if I had to and raise it up.
    I found some nifty cable, ferrules, thimbles and the like, am devising a secondary latch for the tailgate. The pins that hold it up are kinda wimpy. Dont want to trust them soley, with a load and at interstate speeds.
    Sca
    Horkn, MikeInMa and T.Jeff Veal like this.
  9. Sirchopsalot
    Sirchopsalot
    medium city in CT
    Loaded the trailer today with a full load of Red Maple. An inch or better over the rail. The spare had plenty of clearance driving back roads and highway home.
    Stephiedoll, Horkn, eatonpcat and 5 others like this.
  10. T.Jeff Veal
    Good deal, glad it's working out for you.
    Horkn, eatonpcat and Sirchopsalot like this.
  11. Sirchopsalot
    Sirchopsalot
    medium city in CT
    Its good to see you keeping busy!
    That lot you are clearing looks good!
    Horkn, T.Jeff Veal and eatonpcat like this.
  12. T.Jeff Veal
    Thanks, we have a few more to take down
    Horkn, Sirchopsalot and eatonpcat like this.
  13. Sirchopsalot
    Sirchopsalot
    medium city in CT
    20221211_111210.jpg I found these nifty fiberglass markers buried at a construction site. 2 followed me home. A piece of copper pipe and some band clamps, and I now have a way to see the hitch over the truck tailgate..
  14. JD Guy
    JD Guy
    Upstate SC
    Now, just need to see some loaded pictures of that trailer :D. Nice work on the upfit:yes:
  15. Sirchopsalot
    Sirchopsalot
    medium city in CT
    Funny, for the 11 cord we've hauled with it, not one picture of it loaded.
    5x10x18" = slightly more than half a cord over the rails.
  16. Horkn
    Loaded trailer pics are kinda a fun thing to take. I have only missed a couple, and that was when my phone was acting up and needing to be replaced.
    T.Jeff Veal likes this.
  17. Sirchopsalot
    Sirchopsalot
    medium city in CT
    I will have to do that. I will make it my business to do that.
    JD Guy, T.Jeff Veal and Horkn like this.
  18. Horkn
    My buddy wanted this simplicity taken from his dad's to his GF'S place. I figured I might as well make the trip more worth the while by putting a bunch of splits in the trailer as well.
  19. Sirchopsalot
    Sirchopsalot
    medium city in CT
    thats the way to utilize trailer.
    Hate traveling empty.
  20. brenndatomu
    What about the truck bed...? v^>v<^v :whistle: :D
