MS200T Twins
Discussion in 'Chainsaws and Power Equipment' started by LordOfTheFlies, Nov 15, 2022.
  1. Eggshooterist
    Eggshooterist
    Erff
  2. buZZsaw BRAD
    I bought my 201t a couple years ago for $350 and it looked like it was BARELY used. Still had the $679 OPE sticker on it.
    Think my 194T was $400 OTD...April 2020
  3. LordOfTheFlies
    LordOfTheFlies
    NY
    It seems to me that the helicoil is way more than 1mm wider just based on the image of the tap they use. Or maybe I am wrong. Anyone know how big the new hole is? I'll clamp it into the vise and see if I can unscrew the helicoil. That must be it.
    eatonpcat likes this.
  4. buzz-saw
    buzz-saw
    Ct.
    Good eye and that would explain it.
    I have a helicoil kit. Do you need me to measure tap or check drill size?
    LordOfTheFlies and Eggshooterist like this.
  5. Eggshooterist
    Eggshooterist
    Erff
    Any XS stickers on them?
    LordOfTheFlies and buZZsaw BRAD like this.
  6. buZZsaw BRAD
    No, but the 201 needs TLC. Been sitting on the bench since Spring. Dropped a log on it by accident.:emb:
    Blunt impact trauma and i think a bit pricey to fix. Thinking about getting another top handle anyhow.
  7. Eggshooterist
    Eggshooterist
    Erff
    I'll trade that sweet restored Mini Mac for it....
    LordOfTheFlies, buZZsaw BRAD and Chud like this.
  8. buZZsaw BRAD
    Im sure you would! :D What about Troy??? :rofl: :lol:
    I guess paybacks a birch considering all the pestering ive been giving you about your 241! :rofl: :lol:
    Eggshooterist and LordOfTheFlies like this.
  9. LordOfTheFlies
    LordOfTheFlies
    NY
    Well I'll be dammed it was a helicoil after all!
  10. Eggshooterist
    Eggshooterist
    Erff
    I gave Troy to my brother in law for a couple reasons. One, he's getting up there and needed a light saw for the 15" and smaller stuff. Lugging his ms310 and ms311 around limbing ect is getting old. The other reason is, OCD and my having my cake and eat it too attitude, I'll grab Troy and let the $$$$ ported saws stay clean, never enjoying them. So I'm systematically removing that temptation / option so If I need / want to run a saw I'll have no choice but to use them. Hoe lee I'm an odd duck....
    Chud, buZZsaw BRAD and JD Guy like this.
  11. buZZsaw BRAD
    Just so i understand...you get saws ported to not use them??? :confused:
    Eggshooterist likes this.
  12. Eggshooterist
    Eggshooterist
    Erff
    I use them but if I have a beater saw to grab instead, I will because......
    ODD DUCK. :loco: :crazy:
    I have no beater saws now. 5 ported saws and a few vintage Remington Mighty Mite saws. And the Mini Mac you want.
  13. M2theB
    M2theB
    Central Massachusetts
    Just put in a helicoil on a 562 a couple months ago where the plug was just rattling around, destroying the the cylinder threads.
    369494A8-7B5F-46E0-8359-37154319F46F.jpeg 4DFA2169-BF87-43ED-86C4-5AC7E2D169E0.jpeg
    Didn’t figure how a plug could get that loose without some human performance issue.
    I guess I’d go with oem spec unless there isn’t enough purchase, then go with what will work
  14. LordOfTheFlies
    LordOfTheFlies
    NY
    I think I take apart the saw first and inspect the crankshaft and condition of the piston. My guess is it's probably easier to just order a Meteor piston/cylinder kit if everything else checks out.
    buZZsaw BRAD likes this.
  15. MasterMech
    If it's just the spark plug hole bunged up, I'd go for a sleeve-style spark plug thread repair kit. Nothing runs better than the OEM cylinder - usually.
    When using that style kit, installing the correct insert at the right height is critical. Do not leave the edge proud of the sealing surface, and do not have any insert hanging into the cylinder.
    SimonHS and LordOfTheFlies like this.
  16. Scotty Overkill
    It appears they sold you a plug for the 201T, not sure though. I know the 201T plug threads are smaller than the 200T.
    LordOfTheFlies likes this.
  17. LordOfTheFlies
    LordOfTheFlies
    NY
    The good condition MS200T is up and running. After cleaning it all up I filled the tank only to find that the fuel line was leaking right at the gasket seal. Turns out the old line had stiffened up to the point where it no longer made a nice seal.
    The carb also needed a gasket kit (RB69 for the Zama carb) and that worked like a charm as well. Tried to run it without doing that first but it just didn't rev properly and was bogging down. Felt like a fuel supply issue and indeed it was.
    Here's a short video of it running minus the bar and chain. The chain brake cover was so dirty it's a good thing I decided to open up that inner panel. Holy moly it was crusty and disgusting.
    2022-11-28 12.18.04.jpg 2022-11-28 12.18.13.jpg 2022-11-28 15.50.14.jpg 2022-11-28 16.30.49.jpg
  18. LordOfTheFlies
    LordOfTheFlies
    NY
    Setting aside the helicoil ms200t for now. Got the second set of twins. Good compression on one with a broken handle. Bad compression on the other with a good handle. I'll swap the handles and see if she starts. But holy moly the good compression one was caked with spruce/pine sap....And that stuff is black BLACK.....and I had to do a lot of scraping with a flathead and a steel brush to even find the screws for the ignition coil.
    2022-11-30 09.08.08.jpg 2022-11-30 09.08.11.jpg 2022-11-30 09.08.18.jpg 2022-11-30 09.09.48.jpg 2022-11-30 09.16.06.jpg 2022-11-30 09.17.19.jpg 2022-11-30 09.20.11.jpg
    buZZsaw BRAD, SimonHS and Chud like this.
  19. LordOfTheFlies
    LordOfTheFlies
    NY
    Nasty nasty nasty
    Looks better in the first pic....but then I decided to take those covers off.......
    And this is what was underneath. Yikes.
    SimonHS likes this.
  20. buZZsaw BRAD
    :bug: WOW! I think caked is an understatement. Like a time capsule of crud. That softwood sap is some sticky azz stuff.
