Oak Delivery.
Discussion in 'The Wood Pile' started by amateur cutter, Oct 8, 2022.
  1. James Miller
    James Miller
    Hanover PA
    I usually bring a stack of oak and poplar skids home each year for and split it up for kindling. I think it would work as a stand alone way to heat the house in a pinch.
  2. Geoff C
    Geoff C
    NEPA
    Something like 70% of all the hardwood harvested in the US is for pallets.
  3. Chud
    Chud
    The amount of pallets it takes to keep billions flowing into Walmart has to be astronomical.
  4. Haftacut
    Haftacut
    Rives Junction, MI
    That’s depressing! Unless, I guess, you’re the guy making pallets, right?
  5. brenndatomu
    And a lot of them get recycled...either reman'd, or repurposed...a ton of them get chipped and used for mulch(?)...and I believe fuel for chip fired boilers...
  6. Haftacut
    Haftacut
    Rives Junction, MI
    I saw a place this summer that recycled them for mulch….quite the pile of pallets:eek: Around me, the Amish have made a place for themselves in the pallet market. Some pretty impressive outfits putting out a lot of pallets!
  7. James Miller
    James Miller
    Hanover PA
    Around here a lot of the folks actually making the pallets are not making much. But I'm sure the folks running the company are making a killing.
  8. T.Jeff Veal
    That's a nice load of logs, Adam. You'll have fun processing those.
    I've seen a few trailers like that down here, especially at the mill where we took the gum logs. Truck would bring in logs, then load with big bundles of lumber or cants and deliver somewhere else.
    We have a big mill close by, they make lumber, pallets and the big mats used to drive/work on soft ground. We also have a ton of discarded pallets we can get or the recycle truck picks them up.
  9. grandgourmand
    grandgourmand
    Ontario
    Better use as firewood than pallets
  10. amateur cutter
    Agreed!
  11. bear_hunter
    bear_hunter
    indiana
    That’s what I’m talking about !! That’s a great price also.
    amateur cutter and Chvymn99 like this.
