Picked up a cute little winch
Discussion in 'Chainsaws and Power Equipment' started by Screwloose, Aug 10, 2022.
  1. Horkn
    Such a generic name for that company. I looked and looked too. Is there any address beyond the "Dearborn Michigan" on it?
  2. Screwloose
    I'll look at the tag again tomorrow.
    Everything I find points to vehicle transmissions.
  3. Horkn
    And in Dearborn. A few of those around that area, no?
  4. MikeInMa
    When will you be mounting the winch to your ATV? :cool:
    JB Sawman, Ohio, eatonpcat and 5 others like this.
  5. Screwloose
    This one doesn't get mounted. you simply slide it in your receiver hitch.
  6. Screwloose
    Calculations said that it would be too fast for my clumsy azz so I found a rusty NOS sprocket on eBay.
    A little blasting and a bit of yellow and it's good to go. IMG_20220911_153055_(1080_x_1080_pixel).jpg
  7. Screwloose
    Got the driven sprockets swapped. Still have to bore and broach the drive. IMG_20220916_182739_(1080_x_1080_pixel).jpg
    Changed out sediment bowls and installed the Chrysler connector. IMG_20220916_182758_(1080_x_1080_pixel).jpg
    Got the old pipe out and a nos nelson muffler with cap in.
    Time to make up the new wires and swap plugs.
  8. Screwloose
    You should NEVER see these words on Wisconsin wires!!!!
    Or on any magneto !
  9. Screwloose
    Dang !! No spark and the fuel pump leaks......
    So much for the starting attempt.
    Off to get some parts.
  10. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    JB Sawman and Screwloose like this.
  11. brenndatomu
    Points, or electronic ignition?
  12. Screwloose
    Points.
    Fairbanks morse model J magneto.
    Coil has leached a lot of tar, didn't even get the meter out.
    Some azzwipe drilled weep holes in both caps......the caps whose gaskets are supposed to be coated in shellac making it air tight.
    Unless the weep holes were intended for mud wasps, and in those regards they worked fine.
    JB Sawman, brenndatomu and HoneyFuzz like this.
  13. Screwloose
    Anxious to get it going so I can try it out. Friend has a LOT of hung up large dead ash and I'll use this to pull the trees over and skid them out.
    If I run out of time I have 3 more engine driven winches I can use. Pulling large leaning trees back over center and down frequently with the rootball attached is a real rush!!
  14. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    I'd love to be around for that ! Very cool !
  15. Screwloose
    Got my magneto parts. Notice anything &#@%ing wrong!!
    200' of the slimiest cable I've seen. I think it was dipped. IMG_20220924_161809_(1080_x_1080_pixel).jpg
    JB Sawman, HoneyFuzz, Ron T and 3 others like this.
  16. Screwloose
    Before, (check out the screws!)
    And after $150 and 3hrs of work.
  17. Screwloose
    So last night I tried for a while to start it and only got some puffs and burps.
    This morning I wanted to check the timing and since the flywheel screen was off I pulled it around by one of the vanes.
    Mag clicked and it took off running and almost took my finger with it!!
    It's been running around 9 hrs non stop now. Running better and better.
