Dyno tested........Ported 461 vs stock 461
Discussion in 'Chainsaws and Power Equipment' started by Mastermind, Aug 23, 2014.
  1. DexterDay
    I want one... :dancer:
    Chvymn99 and Kg461 like this.
  2. Mastermind
    Mastermind
    Tennessee
    I gotta have one.......I mean.....I just have to.
  3. nate
    nate Banned
    Palmer, AK
    Either 40 or 50lbs isn't too bad to handle.
    I hate lugging around concrete. The usual ones I've bought are 80lbs. Once Lowe's was out of the metal carts so I put a couple sacks in a regular plastic cart. The bottom blew out of it. o_O
  4. Dynomite
    Dynomite
    Pennsylvania
    Burnt five gallons of 92 e free mix since may on dyno runs.
    Kg461, Mastermind, MasterMech and 4 others like this.
  5. SquareFile
    SquareFile
    somewhere
    About how many saws have you tested?
    mdavlee likes this.
  6. MasterMech
    That's happens when you play with 660's..... :whistle::D
    Chvymn99 and SquareFile like this.
  7. Dynomite
    Dynomite
    Pennsylvania
    If I counted right around eighteen. I've run half of that fuel through a brand new 660 I'm doing part testing on.
    DexterDay and SquareFile like this.
  8. Mastermind
    Mastermind
    Tennessee
    Have you tested Ron's 660 yet?
    DexterDay likes this.
  9. Dynomite
    Dynomite
    Pennsylvania
    I'd like to do some fuel useage tests soon. Do you guys think a chainsaw carb would have enough suction to pull fuel through an extended hose that goes out the fuel cap hole and into a measuring container?
    DexterDay and Chvymn99 like this.
  10. Mastermind
    Mastermind
    Tennessee
    Just put the container above the saw.
    Chvymn99 and Dynomite like this.
  11. Dynomite
    Dynomite
    Pennsylvania
    Not yet. Had to watch the kids last night. I want to do lots if testing this coming extended weekend.
    Kg461 and MasterMech like this.
  12. Mastermind
    Mastermind
    Tennessee
    I'm looking forward to that one.
    Kg461 likes this.
  13. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    If you have a look at: http://www.scientificsonline.com/ under lab equipment, you will find what you need. A hanging beaker with hose attached already graduated in ml. This way you can hang it above the saw and connect the carb directly to it, take a reading before run and after.
    SquareFile and Dynomite like this.
  14. Dynomite
    Dynomite
    Pennsylvania
    You the Man. Thanks!
    SquareFile likes this.
  15. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    You can get away cheaper by using a graduated 2-stroke 1qt oil bottle and cap and a brass hose barb from the hardware store.
  16. Ron660
    Ron660
    NW Louisiana
    I'm curious to see the octane tests (110 vs 92). That 110 smells good burning and has a purple tint color. "Purple haze vs Pump gas"!
  17. Dynomite
    Dynomite
    Pennsylvania
    Kinda boring. I was expecting different.
    DexterDay, Kg461, Chvymn99 and 3 others like this.
  18. SquareFile
    SquareFile
    somewhere
    What was you expecting?
  19. Dynomite
    Dynomite
    Pennsylvania
    Mixed. My hunch was saying the 110 would have done worse but Ronn thought it did better.
  20. SquareFile
    SquareFile
    somewhere
    Do you think there might be bigger difference on a stock 660?
