Pioneer P-20 score.
Discussion in 'Chainsaws and Power Equipment' started by WeldrDave, Sep 14, 2022.
  1. WeldrDave
    Nope, I'm not getting into collecting old saws! :headbang: I came across another old saw, just couldn't pass up, Cheap....
    DSCN5255.JPG DSCN5256.JPG DSCN5258.JPG DSCN5260.JPG DSCN5261.JPG DSCN5254.JPG
    M2theB, brenndatomu, Jutt and 7 others like this.
  2. MikeInMa
    I've never heard of them. Nice chain wrapper!
    Thanks for posting!
  3. WeldrDave
    The Chain guard says, "Sears" on it so I'm assuming they were sold in Sears. I have heard of them, never owned or saw one in person until now.
    MikeInMa, Screwloose and In the Pines like this.
  4. Screwloose
    Nice find! I would have bought it in a heartbeat!
    Record this date as then you can tell your doctor exactly when you became afflicted with CAD!
  5. Ron T
    Ron T
    Northeast Ohio....Bowdil
  6. WeldrDave
    I haven't tried yet, I blew out the air cleaner with my compressor, the tank was bone dry but smelled REAL bad, I pulled the plug and looked with my bore light to see if it had "any" oil residue in there, I sprayed some PB and a bit of marvel mystery oil in the cylinder, then pulled it through. It has real good compression. Plug could use a change so I'll get that and I did mix a small about of gas/oil about 32:1 just in case. The cap on it say's 16:1. I'll try later this evening, I put fresh gas in it with some Marvel Mystery oil in it. I'm gonna go slow and I might get lucky. This was a $50.00 find, Fella at my gun club.
    MikeInMa, Screwloose and Ron T like this.
  7. Ron T
    Ron T
  8. WeldrDave
    I just changed the plug with a new one. gonna try soon! Had to come in and feed the pups, get a Beer etc... You know the drill! :drunk:
  9. Ron T
    Ron T
    All too well :coldone:
    WeldrDave and Screwloose like this.
  10. WeldrDave
    Yes, iT'S ALIVE!!!! :cool: It ran real well also. :tears: Took some time to get fuel through the carb and about 10 pulls, but once it did, She ran very well!!! I got a heavy mix in her, and it's still running great. It even idled for about 45 seconds fine. when she quit, it fired right back up on first pull!
    I think having the new plug was the key, It's a Stihl MS 250 plug but closely comparable I'm sure. I keep a few plugs on hand, They matched up perfectly. I'll get a factory Champion CJ6 which is what I took out. Seems to run real strong. I'm gonna let it sit for an hour and see if she'll fire up again. :yes:
  11. buZZsaw BRAD
  12. brenndatomu
    Cool! I have the same saw (basically) mine is aP28, which appears to be just the next gen P20.
    Model Profile: P20
    Model Profile: P28
    My coworker gave me this one...it was his dads and he planned on getting it running again (has just been sitting forever) but now he is paring down his herd and decided to just give me the saw...haven't tried to fire it yet...has lots of compression though! Gas tank smells horrible...I assumed it would need a carb clean...guess I should gas 'er up and try it!
    Screwloose, WeldrDave and Ron T like this.
  13. WeldrDave
    I sprayed some PB blaster in the plug port/cylinder because I assumed this had been dry a Loooooooooong time then pulled it through. It is the exact same 51.4 CC! It's a little animal with a short bar on it. I only have a 14" bar.
    Screwloose and brenndatomu like this.
  14. RobGuru
    RobGuru
    Carroll Valley, PA
    Nice story on the Pioneer there. My father has a Pioneer (don't know which model) that was his firewood cutter when I was a pre-teen and teenager. Note, that was the 1970s. He still used that saw well into the 2010s, although I don't think it's seen much work the last couple years.
    Screwloose and WeldrDave like this.
  15. WeldrDave
    Thanks, it's a (strong) runner! I really don't think this was used much at all. The original bar on it is in nice shape, clutch still has factory paint on it that hasn't worn off, It just has "garage rash" from moving around. This model is from 1973 to 1976, so it's in there somewhere.
    Stephiedoll and Screwloose like this.
  16. WESF
    WESF
    MN
    Pioneers were really common saws in Minnesota in the 70s and into the 80s. I still see them in garages and shops regularly.
    Then Jonsered gained a following in the 80s and 90s, followed by Husqvarna.
    It wasn't until about 20 years ago that I saw many Stihls or Stihl dealers around here. I've still never seen what I'd call an old Stihl in the flesh. The old saws are mostly either red or green.
    WeldrDave likes this.
