Chain experiment
Discussion in 'Chainsaws and Power Equipment' started by isaaccarlson, Aug 18, 2022.
  1. buzz-saw
    buzz-saw
    Ct.
    :makeitrain" :(
    Eggshooterist likes this.
  2. Eggshooterist
    Eggshooterist
    Erff
    I shall try my local online auction first. Quality used items can be had there. I'll just have to stop bidding on saws for a bit.....
    Stephiedoll, Mrxlh and buZZsaw BRAD like this.
  3. MAF143
    MAF143
    North Central OH
    Interesting, I may have to try this with one of my square filed chains. The combination may well shave some more time off of my buckin' around... I know the square filing cuts a lot faster too.
    I do a lot of plunge / bore cuts making candles and if that smooths that out some more, that would be awesome.
    Hinerman, walt, buZZsaw BRAD and 2 others like this.
  4. Eggshooterist
    Eggshooterist
    Erff
    I did up slightly used Stihl PM3 full chisel chain today for this experiment. Removed the safety bumpers then did the mods listed in the first post. I haven't ran it yet. Probably won't until at Kevins GTG. I'll have a new Picco Super yellow chain with me in case this is a failure on my part. That lil air pencil grinder was the weapon of choice this time around. Disc for the rakers and heels and the stone for the rivets.
    IMG_20220902_141445501~2.jpg IMG_20220902_124009508~2.jpg IMG_20220902_130130314~2.jpg
  5. Barcroftb
    Barcroftb
    The Mitten
    MAF143 likes this.
  6. isaaccarlson
    isaaccarlson
    Colfax, WI
    I saw a chain last week that was modified safety chain where they cut the bumper off but left a piece next to the raker and squared off the front of both. He said it helped push chips out of the cut and kept them from getting under the next cutter. I saw the chain cut and it was really moving the chips. I picked up a chain like it and will combine all the mods and see how it turns out.
    buZZsaw BRAD and Eggshooterist like this.
  7. Eggshooterist
    Eggshooterist
    Erff
    What is the reason for clipping the heels? Help chips exit easier? Less weight? Both? That area shouldn't be touching wood as its lower than the working edge. I'm totally new to doing anything outside the norm on a chain so thats why I'm asking.
  8. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  9. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    nice pictures...!!!!
  10. Eggshooterist
    Eggshooterist
    Erff
    Thanks bud. I try lol
  11. isaaccarlson
    isaaccarlson
    Colfax, WI
    it lets the chips get out easier.
  12. Eggshooterist
    Eggshooterist
    Erff
    Thats what I was thinking because it opens up the area they "squirt" out of. I probably should test mine before the GTG.
  13. isaaccarlson
    isaaccarlson
    Colfax, WI
    You could lower the drive links too, especially the one under/behind the cutter. DBCFFB6E-9343-432C-BBD6-41F36A802AC6.jpeg
    Sirchopsalot and Eggshooterist like this.
  14. Eggshooterist
    Eggshooterist
    Erff
    That should be easy enough. Thanks for the tip.
    Sirchopsalot likes this.
