Gutting the Dolmar 7910 Muffler
Discussion in 'Chainsaws and Power Equipment' started by Barcroftb, Aug 4, 2016.
  1. M2theB
    M2theB
    Central Massachusetts
    With the Mod
    Before the Mod.
    I haven’t attempted to tune it yet
  2. Horkn
  3. huskihl
    huskihl
  4. huskihl
    huskihl
    Neighbor pizzer offer
    J. Dirt, Ron T, Stephiedoll and 9 others like this.
  5. Horkn
    Eric VW, Ohio, Barcroftb and 2 others like this.
  6. Ohio
    Not Ohio
    Anyone got a picture of the tool for the H adjustment on the carb of a makita 7900? Asking for a friend.
    Horkn, Eggshooterist, M2theB and 2 others like this.
  7. huskihl
    huskihl
    Think it’s a DD. SOS Ridgerider will know
  8. M2theB
    M2theB
    This saw has that cap blocker on it.
    Plan on digging into it tomorrow and will report back with pics
    Agree, SOS Ridgerider would be my go to
  9. M2theB
    M2theB
    First blocker. Took that collar off with a chisel and reached in behind to get the rest
    Second blocker, H side with poured in epoxy or similar. L side is just dirty
    Drilled a small hole to get a start on what I was dealing with
    Lots hand work with a small razor and pick
    I got enough out that I could start to turn H adjuster. Kept going until the whole block backed out.
    A little more clean up. Didn’t see a reason to keep chasing the rest of the epoxy. Had full seat capability at this point.
    First blocker, cleaved.
    Carb
    Barcroftb, Horkn, Chud and 2 others like this.
  10. huskihl
    huskihl
    I have never seen one like that. What a pain in the dik
  11. M2theB
    M2theB
    I guess Home Depot figures if a customer is willing to go that far then he’s probably not going to toast it in the tune.
    Maybe it’s a job application.
    Horkn, The Wood Wolverine and Ohio like this.
  12. huskihl
    huskihl
    Possibly. I guess the only Home Depot rental saws I’ve been into were already owned by someone else first and maybe they had already defeated them
  13. M2theB
    M2theB
    and I think about 1 and a third turns is the is HD secret recipe. Somewhere between a quarter and third.
    Ohio and The Wood Wolverine like this.
  14. huskihl
    huskihl
    That depends on the age. Newer ones run close to two turns out. Early ones about one turn out
    Horkn and Ohio like this.
  15. M2theB
    M2theB
    This one was set there before being perma plaqued
    Horkn, Ohio and huskihl like this.
  16. Ohio
    Not Ohio
    I saw that miller mod saws tack welded the spacer that used to be attached to the slr tube to the back half of the muffler. What is the best option if you don't know how to tig or braze?
    M2theB and Horkn like this.
  17. huskihl
    huskihl
    Affixing it would be better, but the bolts go through it and hold it in place. It needs to be there as a spacer
  18. Horkn
    I'll have to take a look at my ex rental 6421
    M2theB and huskihl like this.
