Oh No! Front Differential or Transfer Case Trouble
Discussion in 'Chainsaws and Power Equipment' started by Ralphie Boy, Jul 21, 2022.
  1. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    Driving the BX 2660 back to the shed today when it started making a hell of a clanging and banging sound. I thought something was goofy with the mowing deck but the mower was not engaged and nothing was hung up on it.
    After driving a few more feet the front wheels briefly locked up then went free. I tried shifting out of fwd but that did not seem to do anything. Okay armchair and real mechanics what's the problem here?
  2. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    its orange....
  3. Eggshooterist
    Eggshooterist
    Erff
    Do you always run it in 4x4 or only in conditions that require the added traction?
  4. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    the amount of teryaki sauce in the unit was probably insufficient
  5. Ralphie Boy
    Ralphie Boy
    :rofl: :lol::rofl: :lol: I couldn't get a green one when I needed it.
  6. Ralphie Boy
    Ralphie Boy
    Pretty much all the time as my front yard tops out at a 21% incline.
  7. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    hang in there buddy.....
  8. Ralphie Boy
    Ralphie Boy
    Turns out it's not as bad as I thought. There is an aluminum pin connecting 2 parts of the front drive shaft that sheared. It looks like an easy fix assuming there isn't something binding that caused ith pin to shear. The parts were a bit over $4.00
  9. Warner
    So the teriyaki sauce level was to spec.?
  10. T.Jeff Veal
    Hope that is all that's wrong.
  11. Screwloose
    As much of a pita as it sounds you should only use 4wd when needed. When turning the wheels need to slip as they are turning different speeds but are all geared together. A simple turn on pavment will wind it up tighter than dumf's pink panties. Something has to give.
  12. Warner
  13. Ralphie Boy
    Ralphie Boy
    Good advice and I will follow it once it's fixed.
  14. Canadian border VT
    C591D936-BF28-478F-A689-273D6C84582A.jpeg Mine if 4wd is needed a lot (read snow ice) I lift front tires off ground with bucket let them spin and it works. First tell tale sign it wants to stay in 4wd when I try to take it out. Also only use 4wd at low speeds. I respectfully disagree with SKEETER McCLUSKEY my good friend/neighbor has had 3 John Deere a 35 55 and now 75 hp with cabs all have issues since I got mine all bought new.. where my 54hp Bota has been dead reliable. He borrows Bota when his 4wd doesn’t work….
    In short some jobs 2 tractors are good
    We baby JD at top and
    Beat the Bota
    Screwloose likes this.
