How to calculate cord volume from log size?
Discussion in 'The Wood Pile' started by MaineMtnMan, Jul 15, 2022.
  1. MaineMtnMan
    MaineMtnMan
    How do you figure the volume of these logs?
    2 pieces cherry. The larger is 6’ 6” to the crotch. 20” wide at the base. The other is 5’ and 13” wide
  2. Yawner
    Yawner
    Louisiana
    If I did it right, I get 14.18 cu ft for first one, 4.61 cu ft for second one, total of 18.79 cu ft.
    I use an app called Timberlog. I assume that it is assuming that the log has no taper and it seems unlikely that it would not have a little, so, the numbers are likely slightly high is my thinking.
  3. Flamestead
    Flamestead
    Windsor County, VT
    This passes the eyeball test - the 13” log will have darn close to a cubic foot of volume per foot of length (same taper assumption). If both logs were the same it would be 11.5 cu ft. But one is larger, and then there is the air between splits.
  4. MaineMtnMan
    MaineMtnMan
    Thanks for the math and the resource, I'll check that out
  5. The Wood Wolverine
    Firewood & Cord Calcuations
    Scroll down to the second calculator. Just enter dimensions.
  6. MaineMtnMan
    MaineMtnMan
    Awesome thanks
  7. MaineMtnMan
    MaineMtnMan
    So roughly 1/4 cord if I'm correct
  8. MaineMtnMan
    MaineMtnMan
    Actually I guess .15 cords
  9. buZZsaw BRAD
    I use this guide for standing trees. Pretty accurate.
    Estimating Firewood from Standing Trees - UC ANR
