Need advice..
Discussion in 'Chainsaws and Power Equipment' started by Chaz, Jul 2, 2022.
  1. Chaz
    Chaz
    Southwestern NY
    Chainsaw started running horrible today.
    I've had some issues with bogging when going from idle to wide open for some time, but could get the rpm's up and maintain through the cut.. not today, anything over 1/2 throttle bogs and/or stalls the saw.
    Couldn't keep rpm's up through a cut, got rather frustrating.
    Air filter is clean, checked plug, was slightly over gapped according to the manual, so corrected that, no appreciable difference.
    I think the fuel filter could need changed, but couldn't find that in the manual I have on my phone.
    It's the only other item I can really figure would be causing this problem.
    Audio sucks, think the mic was overloaded being so close. But here's a quick vid..
  2. Chud
    Chud
    It sounds like it needs a carb adjustment. I’d try a quarter turn counterclockwise on H and see if it improves in the cut. An 1/8 turn cc on L may clean up the bog off idle. If that doesn’t work set both back to initial factory settings. A gooogle search of initial carb settings for your saw will give beginning carb settings.
  3. Eric VW
    Direct embedded your vid Chaz.
    Screwloose, eatonpcat, Ohio and 3 others like this.
  4. Chaz
    Chaz
    Southwestern NY
    Thx Eric... I was wondering why it didn't come up right. But I did the "copy link" from my user acct.. dunno.
    Thx
    :cheers:
    :handshake:
    Screwloose, Eric VW and M2theB like this.
  5. Chaz
    Chaz
    Southwestern NY
    Weirdest part, somehow the video had 63 views when I linked it here.
    Who in the heck is that damm bored?
    :rofl: :lol::rofl: :lol:
    Edit...
    Well, I see I misspelled down..
    :picard:
    Can't edit the title, but now it's got 211 views
    Some bored people out there.
    :eek:
  6. M2theB
    M2theB
    Central Massachusetts
    if I hear what I think I hear
    Limited coil is doing its thing, protecting the saw.
    Do you think it accelerating to the top faster than normal?
  7. Chaz
    Chaz
    Southwestern NY
    Limting/limiter coil?
    I certainly see that as possible, wasn't aware that it was a new enough saw to have such implementation.
    As to accelerating "faster than normal".. it seems to be "normal".
    It never went from idle to WOT without a pause.
    But that seems normal.
  8. Chaz
    Chaz
    Southwestern NY
    I will try that.
    I'm questioning why today was so much different than earlier this week.
    :sherlock:
    Screwloose and Eric VW like this.
  9. Chud
    Chud
    Hopefully it’s not an air leak. If you eliminated fuel and air filter obstruction, it could be bad fuel, or heat and humidity change.
    If it was a Husqvarna, you may have just looked at it wrong :rofl: :lol:
  10. JimBear
    JimBear
    I would just pull the carb & clean it out. What you are describing sounds like debris in the carb.
  11. M2theB
    M2theB
    what saw is it?
  12. Chaz
    Chaz
    Southwestern NY
    That is always a possibility. Kind of last stop on my list.
    034AV
  13. The Wood Wolverine
    Maybe it’s time for some new fuel line, a fuel filter and a carb rebuild kit. To me the vid sounds like super slow acceleration. Clogged carb screen, clogged [fuel] filter, very soft line.. many small ticket items that could be eliminated with some maintenance.
    Edit: and even a super clogged muffler screen could contribute.
    Before any of that, I would definitely be trying a different batch of gas/mix oil. Dump all the old out etc.
    Chaz, BuckthornBonnie and Screwloose like this.
  14. buZZsaw BRAD
    :thumbs: :rofl: :lol:
  15. The Wood Wolverine
    A Stihl...:D
    Chaz, Screwloose, M2theB and 2 others like this.
  16. M2theB
    M2theB
    Ah
    Well it’s more clear now
  17. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    034- unlimited coil.
    I agree with the above… time to go through the fuel system. Also take the time to properly split the air filter and clean it. Replace if necessary.
    The fuel and impulse lines should be inspected. The impulse is just a piece of Stihl line behind the carb air box. The fuel filter can be fished out of the tank using long pliers, bailing wire, etc.
    Running issues with 1125 saws should immediately be investigated. They’re old now and all those rubber parts (including the carb gaskets and diaphragms) have a life expectancy.
    brenndatomu, Chaz, M2theB and 3 others like this.
  18. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    If the fuel system (and compression… and bottom end) get fixed up, that saw will last another couple decades.
    Oh, and in the 20ish 1125s that I’ve been into, I’ve only found one dead coil. I’m one of the eBay lurkers who bid on used oem coils for this series. Aftermarket are junk.
  19. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    And give that crank a good wiggle on the pto side. It’s probably tight, but I always start there and then fuel, compression, spark… in some sort of order :thumbs:
