John Deere X300 Rebuild
Discussion in 'Chainsaws and Power Equipment' started by LordOfTheFlies, Jun 3, 2022.
  1. LordOfTheFlies
    LordOfTheFlies
    NY
    Glad you got it! Back a few years ago I think it was only like $40 or something which made it even more of a no brainer. You should take a video of you changing the tire! I would have except it only took me 2 minutes to do the first one and I got too excited and did the 2nd one in 30 seconds!! It sure would have been useful to use it to remove the tires. Already paid for itself. Enjoy!
    Skier76 likes this.
  2. Dok440
    Dok440
    NorCal
    Regarding the spindle that won't take grease- On my Husky lawn tractor the spindles have zerk fittings but it turns out the bearings were completely sealed on both sides- adding grease to the zerk would never reach the bearing! I removed the inner seals so I can keep the bearings greased. Possible you could be running into the same situation?
    Brad
    LordOfTheFlies likes this.
  3. LordOfTheFlies
    LordOfTheFlies
    NY
    Yeah I'm not sure what's going on because the other zerk fitting does take grease and I can see it coming out the other side. So I can't imagine one would be sealed and one would be open.....you'd think they'd both behave the same. For now both blades appear to spin just fine and cutting wise I haven't had any obvious issues I can see.....
  4. MasterMech
    1/3rd rule: Never remove more than 1/3rd of the grass length in one cutting.
    Mulching is for those that abide by the 1/3rd rule religiously. When following this rule, most outside observers would question if the lawn really needs to be mowed. In your video, you were moving right along and taking a pretty good bite. That's a lot of material for the machine to process in not a lot of time. I think you're going to find that switching to just the mulch plug will actually reduce that performance further and I don't expect it would help with processing leaves either. Mulching is more than just blocking the discharge chute and trapping the clippings under the deck. Efficient mulching is cutting the grass clippings with the outer radius of the blade and moving those clippings to the inner radius of the blade where they get re-cut as they fall back down into the lawn. The raised edge of most mulching blades is just for this purpose, and many are twisted in such a way that they produce no lift, or actually pull air DOWN in the center of the blade, encouraging this recycling action. Switching to a straight-edge blade like the Gator, with a high sail and no almost no raised cutting edge, further discourages the recycling action. Gator's are great for reducing clippings and leaves while side-discharging. And the serrated sails might do great with processing leaves. But the lack of that raised cutting edge means they will rely solely on those serrated sails to beat grass clippings to a pulp. I think there are minor clearance issues with the plastic baffle as well. Said baffle does much more than just reduce volume under the deck, it encourages that clipping recycle action and fills the front "tunnel" that is so desirable for side-discharge operation. With that tunnel open, clippings will tend to migrate to the right side of the deck and overload the right blade, leaving a line of clippings/clumps/leaves along the right-hand side of the pass. That's unavoidable on a multi-spindle deck where all of the blades spin the same direction, and that leads us into......
    The 42C and 42X deck is quite versatile. It side-discharges and bags (without a blower) quite well and with a full mulch kit (plastic baffle and OE blades), mulches as good or better than any other convertible deck design. But mulching is something where the best performance is attained by using a a tool specifically tuned to do the job. Deere used to offer a deck called the Piranha Deck, it was a 3-spindle, cross-blade (6 blades!) 44" deck with the two outer spindles swept WAY back. This prevented the deck from having a forward tunnel and encouraged loading of the center blade rather than dumping clippings at the right edge. The deck could also be used as a rear-discharge but that's a different discussion. They were great performers, offered two-sided trimming, but suffered from the same problems all dedicated mulching decks do, they can't process heavy grass well. Expensive to manufacture, low take-rate, and it's placement on premium priced equipment (LX series and up) led to it being quietly discontinued somewhere around 2005.
    Enter the Freedom 42, on the LT and LX series tractors, a counter-rotating, parallel (no offset) twin spindle mower deck, with permanently closed in blade chambers. The parallel counter-rotating blades necessitated a cogged timing belt drive that required much more discipline to service properly. Mulching performance (and turf striping!) was second to none really, at least in a multi-spindle design. The counter-rotating blades meant that clippings tended to migrate to the center of the deck, where they would get distributed equally back into the two blades for recycling. When over-loaded, you could get a streak of clippings right down the center of the pass, but everything about this deck was optimized to mulch. While Mother Deere was clear that this deck was intended for well-manicured lawns that were mowed frequently, dealers still sold them to the guy with every vehicle he's ever owned (save the one he drove to the mower shop) on blocks (maybe) in the yard. Striking solid objects with the blades would usually result in a broken timing belt, and bent blades. Almost always over $100 in parts, even 20 years ago. Plus, setting the belt tension properly was absolutely essential to getting it to track around the drive properly and there were many instances of a DIY customer ignoring the included instructions and returning to the dealership with a brand-new, broken belt, and sour attitude, as the broken belt meant that the new blades (remember, counter-rotating, interference design....) were now damaged as well.
    The Freedom 42 was discontinued when the X300 series was introduced in 2006. The 42M option for the X300 was a new shell design that sought to alleviate the mechanical booby traps (from the Freedom 42) while retaining as much dedicated mulching performance as possible. Still a counter-rotating design, it offset the blades exactly like the 42X (and most other twin-spindle) deck did using a double-sided belt drive and a couple extra pulleys. This eliminated the mechanical blade interference from the Freedom 42 design, and the timing belt. While the deck was much more tolerant of abuse, it still suffered from the same problem it's predecessors did. You couldn't really wade into 12" tall grass and expect this deck to perform. You would get clippings and clumps if you went on vacation and came back to heavy growth. And if you were mowing frequently enough to get great results with a dedicated mulching deck, the 42X convertible design would mulch just as well to the untrained eye, really only giving up the two-sided trim ability. Owners liked options as well, and you lose the option to bag or discharge with the 42M. So the 42M option went away when the X300 series was refreshed a few years back.
    All multi-spindle mulching deck designs are a compromise. You must give up some clipping recycling action to accommodate the extra spindles/width. There are some phenomenal mulching designs that can process a bunch of grass/leaves, even better than the above mentioned decks. But they are all single-spindle designs. Toro Super Recycler walk-mowers, for example. Or a Deere TerrainCut 7700/8800. Get out your wallet for one of those.....
    Your lawn type dictates what's best for mowing height and clipping management. On non-irrigated, cool-season grass, cutting in the upper end of the recommended range for your grass type(s), then you probably aren't going to leave visible clippings, even in side-discharge mode. When the weather is cooler, and the soil is moist, cutting in the 2-3" range produces that awesome "barefoot" lawn. But the grass is likely growing vigorously in these conditions and to remain within the 1/3 rule, you will have to mow often, usually more than 1x week. Raising the height will ease up on the mowing frequency, but the turf will not be as dense. You must find balance in the Force Padawan. :D When summer temps are consistently in the mid to upper 80's or higher, this stresses cool-season turf and it will weather the summer far better at a taller height.
    And y'all thought I had a chainsaw problem........... :rofl: :lol: :whistle:
    Skier76, JD Guy, Rothk and 2 others like this.
  5. MasterMech
    Those spindles aren't terribly difficult to remove the center shaft from and clean it out. Gives a good view of what kind of shape the bearings are in too. Make sure the bearings do not have inner dust seals installed.
    LordOfTheFlies and brenndatomu like this.
  6. MasterMech
    Very rarely unless you "calibrated" the deck height. It's usually significantly lower. The 42C/42X is easy to measure through the discharge opening. But if the deck is raked forward properly, the most accurate measurement is up front, with the blade pointing at 12 & 6 o'clock. Measure the tip of the blade to the ground. You can cut some "gage blocks" from scrap lumber, use a brick, etc. as well. Creative is good. There are dedicated tools for this task but..... This is also a good way to observe what 1-2 psi adjustment/loss in a tire (especially a rear), does to cut height.
    When adjusting the deck level, start with 4 properly inflated tires, level side to side first, then front to back. Front edge of the blade should swing 1/8"-1/4" lower than the back. Calibrating the height can take a little more time, close is good enough, I recommend mental adjustments for minor discrepancies.
    JD Guy and LordOfTheFlies like this.
  7. LordOfTheFlies
    LordOfTheFlies
    NY
    I feel like I need to read that over 5 times to full absorb everything you said. Thank you for elaborating.
    And to clarify, my focus will be on processing leaves. Cutting the neighbor's lawn was just for fun really and to help him out. Turns out he has a deal with the landscapers where he lets them park their truck in his commercial lot and they in turn mow his lawn. So this likely won't be a regular thing for me to do, although I wouldn't mind doing it.....again just for fun!
    I think the hole in the mulching insert was hindering my cut because I was definitely leaving behind some clumps. I probably should have slowed down a little bit in hindsight but I did have the throttle lever at WOT. Btw I don't have any shock absorber for the pedals. It's a hard connection via a rod to the tranny lever.
    I will definitely let you know how it goes with the Gator blades. Fall is around the corner even though summer just started hahahaha. I will probably mow his lawn again with the Gator blades just to test 'em out before the fall.
    I watched this video below and couldn't believe the leaves literally just disappearing into thin air. Obviously they got chipped up and dropped to the ground but that is the end result I'm looking for on my property as I have all leaves and almost zero grass.
    I'll do that. Thanks.
    Thanks for the info. I followed the directions in the manual. For my purposes I don't think I need to get all into optimizing deck height but obviously I don't want a super slanted crooked cut either.
  8. Rothk
    Rothk
    WVA
    I agree with what was said here. For overgrown grass I like gator blades + side ejection. For grass I am mowing twice a week, I like a mulching blade with a closed deck. Either way I mow high.
  9. MasterMech
    That's exactly how many golf courses, parks, etc. deal with leaves. Just on a little different scale.
    If you can get into them before the leaf cover gets quite that heavy, you'll see even better results. Note the amount of "blow-out" coming from the right side of his machine.
    There used to be leaf baffles or anti-blowout baffles for these decks. Not sure if they are still available. But the plastic mulch plug takes care of a lot of that.
  10. MasterMech
    I really doubt that little bit of damage was the cause for the clumps. I have seen far worse! You were eating quite a bit of grass in that cut. Reducing ground speed, or even better, picking up your cut height would have given a clean pass. Even a 1/2" can make all the difference. WOT is the way.
    JD Guy, LordOfTheFlies and Chud like this.
  11. LordOfTheFlies
    LordOfTheFlies
    NY
    In this pic it seems to me I'm barely taking any bite at all. But without getting my face on the turf and taking a pic I do get it's hard to tell.
    In any case, I am excited to try the mulch plug and the gator blades. I will raise the height a bit and won't go full throttle on the pedal itself.
    I also fixed the hood. I used a 50ml tube of DP420NS ($40) and managed to reattach all the broken plugs except for one which did snap. That one had a lot of meat missing on one side so I figured that would be the one to fail. I ended up drilling a hole and using a 8-32 electrical machine screw that was extra long and had to go out and pickup an assorted washer, nut kit.
    It feels nice and tight and unless someone rips open the hood this should last a while. Of course I bent one of the headlight tabs back to straight (OCD me) and it broke so now I have another one on order for $5 at the local dealer. Lesson learned there. That's what I get for wanting that plug to come out straight.
    2022-06-22 10.46.25.jpg 2022-06-22 10.46.28.jpg 2022-06-22 10.46.33.jpg 2022-06-22 10.46.36.jpg 2022-06-22 10.55.52.jpg 2022-06-22 17.56.49.jpg 2022-06-22 21.20.53.jpg 2022-06-23 10.19.34.jpg 2022-06-23 10.19.39.jpg 2022-06-23 10.21.02.jpg 2022-06-23 10.21.06.jpg 2022-06-23 10.22.47.jpg 2022-06-23 10.22.50.jpg 2022-06-23 10.23.01.jpg 2022-06-23 10.20.58.jpg
    Skier76, Stephiedoll, JD Guy and 2 others like this.
  12. eatonpcat
    She looks new, great rehab thread...thanks for sharing!
    Chud and LordOfTheFlies like this.
  13. JD Guy
    JD Guy
    Upstate SC
    Really looking nice! If you get really OCD you can probably even order new decals for that re-fabricated hood:D
  14. LordOfTheFlies
    LordOfTheFlies
    NY
    Thanks man! Hope my posts help someone in the future.
    I'm a little OCD....but not quite *that* OCD.
    I was, however, considering painting it with U-pol Raptor. I used that stuff on my side steps on the Tacoma as well as on a Radio Flyer rebuild.
    It would look gnarly! And give it some protection. That stuff is super strong. I have zero chips and zero rust on my side steps.
    eatonpcat and JD Guy like this.
  15. LordOfTheFlies
    LordOfTheFlies
    NY
    I drove past the lawn I mowed in the evening after the pool as the sun was setting and wouldn't you know there was the neighbor sitting outside his front door just admiring his lawn. Yeah baby. hahahahahaha. I walked by a little later and snapped a pic.
    Rothk, Skier76, eatonpcat and 2 others like this.
