ms362 questions
Discussion in 'Chainsaws and Power Equipment' started by Erik B, May 22, 2022.
  1. Erik B
    Erik B
    Western Wisconsin
    I recently picked up a used ms362 and I have used it once. It runs great. I put a 20 inch bar and chain on it today but I cleaned the saw a little bit first. I noticed a loose plastic piece next to the break and it came out just by picking it up. I have pics showing the piece and where it goes. I am also wondering if the chain catcher needs to be replaced.
    The one picture shows a screw driver pointing to where the plastic piece goes.
  2. huskihl
    huskihl
    One or both pieces of plastic are broken. The big piece holds the smaller one in.
    Chain catchers work until they don’t. Yours looks like has a few more derails on it before it needs replacing
  3. Erik B
    Erik B
    Western Wisconsin
    huskihl The first two pics show the same piece of plastic, the first one out of the saw and the other one in the saw. Where is the second piece of broken plastic?
  4. huskihl
    huskihl
    There are differences between models, but the upper piece of plastic that surrounds the top half of the clutch I figured held the lower piece in. I believe I have one out in the garage. I will try my best tomorrow to take a look at it and see what holds that bottom piece in
  5. Erik B
    Erik B
    Western Wisconsin
    Thanks huskihl . It would help if I could see what that area of the saw is supposed to look like. Got any pics?
  6. Lennyzx11
    Lennyzx11
    Bennington Vermont USA
    I have a M362 new from dealer. I’ll get some pictures in the morning for you.
    Lenny
  7. LordOfTheFlies
    LordOfTheFlies
    NY
    Here's the full parts diagram.
    Stihl MS 362 Chainsaw (MS362 & C) Parts Diagram
    And here is the section on the area in question.
    It appears to me that the small plastic piece is not broken and is meant to be there. Part labeled #20.
    It looks very similar to the small part on my MS460 that actually had a bolt holding it in place.
    Screwloose, Erik B and T.Jeff Veal like this.
  8. LordOfTheFlies
    LordOfTheFlies
    NY
    I'd order a new chain catcher now so that when it happens you can just slap 'er in there. Yours is almost done.
  9. Erik B
    Erik B
    Western Wisconsin
    LordOfTheFlies Thanks for the info. I also found this blow up of parts and noticed #20 seemed like what I was looking at. Stihl calls it a 'cover'.
    Screwloose and LordOfTheFlies like this.
  10. LordOfTheFlies
    LordOfTheFlies
    NY
    You're welcome.
    Comparing your image to this image I don't think it's broken, is it? Do you still need to replace it?
    upload_2022-5-24_15-10-53.png [​IMG]
    T.Jeff Veal and Screwloose like this.
  11. Chud
    Chud
    It appears to me like the thumb looking protrusion is broken off short.
  12. LordOfTheFlies
    LordOfTheFlies
    NY
    I don't know. That's not the greatest pic but I think it's got that weird hump on the right side (i.e. the oppose corner up and to the right of your yellow arrow) that matches his piece. The contrast is not great on that pic I posted. :binoculars:
  13. Erik B
    Erik B
    Western Wisconsin
    One piece of it may be broken but not enough to cause problems. I may order a new one along with a chain catcher. Thanks guys.:handshake:
    T.Jeff Veal and LordOfTheFlies like this.
  14. LordOfTheFlies
    LordOfTheFlies
    NY
    Chud You got better eyes than me! hahaha.
    For reference I had to order both the larger and the smaller piece for the MS460 and it was $18.97 to my door.
  15. huskihl
    huskihl
    Didn’t mean to drop the ball on checking this out for you. Had a busy couple days trying to run down fixes and parts
  16. Erik B
    Erik B
    Western Wisconsin
    huskihl You wouldn't by chance have those two parts, would you? The plastic one and the chain catcher.
  17. huskihl
    huskihl
    I don’t have them as extras. I have a new MS 400 awaiting port work in the garage and they use the same parts I believe
  18. huskihl
    huskihl
    A0E31754-06ED-4D98-9DE2-5C9CBA70C410.jpeg 236E62BB-5D56-4C2F-83ED-894BCDF8852D.jpeg
    The white piece…..it just snaps in place. These 2 white tabs click into the case. And the front is held in place by the bar plate
  19. Erik B
    Erik B
    Western Wisconsin
    T.Jeff Veal, huskihl, Ohio and 2 others like this.
  20. brenndatomu
    Those are some mighty fine pics, aren't they?! :thumbs: :handshake:
    (notice they are all real close up so as to not accidently disclose any top secret sausage stuffing techniques ;))
