Milling Honey Locust
Discussion in 'The Sawyer Room' started by buZZsaw BRAD, May 17, 2022.
  1. buZZsaw BRAD
    How stable is it after being cut? Have a score of it to cut and may save a few logs for the mill. I know its very rot resistant too.
  2. Chvymn99
    I would not agree with that statement.
    buZZsaw BRAD and T.Jeff Veal like this.
  3. The Wood Wolverine
    What I've found... if a log has lots of limb/crotch sections, you'll want to heavily top weigh and/or strap it. I've gotten lots of bow/twist/cup (and the kitchen sink) in those instances. If it's a nice straight clear log, I get less of those tendencies. But I still sticker stack and use cinder block to keep flat.
    T.Jeff Veal likes this.
  4. buZZsaw BRAD
    Cancel the milling. Tree service took all the wood on the ground including a couple of mill logs. I turned the spar into firewood.
  5. buZZsaw BRAD
    I had thought i heard it on here somewhere. I googled HL and this was the description under "timber"
    Timber[edit]
    Gleditsia triacanthosMHNT
    Honey locusts produce a high quality, durable wood that polishes well, but the tree does not grow in sufficient numbers to support a bulk industry. However, a niche market exists for honey locust furniture. It is also used for posts and rails because of the dense, rot-resistant nature of the wood. In the past, the hard thorns of the younger trees were used as nails and the wood itself was used to fashion treenails for shipbuilding.[citation needed]
    I found a couple two year old rounds buried recently at storage and only the bark was loose and really little to no evidence of decay. Ground contact with no top cover either. Maybe the hybrids arent as rot resistant?
  6. buzz-saw
    buzz-saw
    Ct.
    Thats a bummer!
  7. chris
    Don't know about Honey locust being rot resistant but was always a term applied to Black Locust.
