Stihl MS500i Chain Catch
Discussion in 'Chainsaws and Power Equipment' started by LordOfTheFlies, May 1, 2022.
  1. LordOfTheFlies
    LordOfTheFlies
    NY
    That's weird because you are mounting your chain catch in a 2nd hole that I don't have on the 500i in my garage. My chain catch is mounted on the bolt for the spike. You sure that's the 500i??
    I think your last pic is the 500i. I can see the anti-vibe spring on both your 3rd pic and my pics up top.
    amateur cutter and buZZsaw BRAD like this.
  2. LordOfTheFlies
    LordOfTheFlies
    NY
    You can also see the 2 screw holes in both your 3rd pic and my pic.
    amateur cutter likes this.
  3. buZZsaw BRAD
    i check and repost...stay tuned
  4. buzz-saw
    buzz-saw
    Ct.
    I still need to check my fleet and see who has what.
    Some with the double dogs I know have the roller , not sure on the rest of them.
  5. LordOfTheFlies
    LordOfTheFlies
    NY
    I received a MS660 chain catch today and just figured I'd snap a pic to show the difference between that and the one for the MS500i.
    MS660 on top.
    MS500 on the bottom.
    amateur cutter and Chud like this.
  6. buZZsaw BRAD
    Took better pics this afternoon.
  7. buZZsaw BRAD
    My original pics in first post were the wrong order...my bad. Sorry for any confusion.:confused:
  8. LordOfTheFlies
    LordOfTheFlies
    NY
    No worries mate. Appreciate the pics.
  9. buZZsaw BRAD
    Glad to help out. Why are you fixing a 500i?
  10. LordOfTheFlies
    LordOfTheFlies
    NY
    Tune up. I can't believe I had to spend 5 minutes on each air filter (2 saws) with a nylon brush because of how much crud was stuck in there.
    First saw's spark plug had a tip that was almost gone so a big gap. Clutch area was totally dirty too, caked up all around the worm gear and oil pump, brake band, and also cleaned the chain brake area was caked with sawdust and oil. Dressed the bar, cleaned.....
  11. amateur cutter
    I'd drill the dogs and put the ceramic roller in there if it was me. Way better setup and doesn't usually trash the teeth if you throw a chain.
    LordOfTheFlies, Chud, JimBear and 2 others like this.
  12. Barcroftb
    Barcroftb
    The Mitten
    Yep this! Pick a spot on the dogs that will clearance the chain. Remove both dogs and drill a hole roughly the same size as the roller chain catcher. Voilà, you now have a chain catcher that will not bugger your chain…
    For example: Stihl style roller chain catch on a dolmar 7900
    6686853F-029D-451C-8F3A-D0F961D1D36F.jpeg 4FE2D267-C6A0-42AE-AB1A-12B5C58103B0.jpeg
  13. huskihl
    huskihl
    + one size fits all :picard:
    LordOfTheFlies and Barcroftb like this.
