Ethanol fuel or Aviation fuel
Discussion in 'Chainsaws and Power Equipment' started by Kevin Smith, Aug 21, 2014.
  1. mdavlee
    mdavlee
    I seen 110 for $6.99 today. I don't think I'll be trying it at that price.
  2. PullinMyPoulan
    PullinMyPoulan
    Manistee National forest
    KRL nails it I have been telling people about puregas for a while but I hear the line, "I run only the premium in mine". I am very fortunate to have a station that is only 16 miles away and they carry 90 ethanol free which is about 30 to 40 cents more than regular gas.I usually get 5 gallons at a time but only mix a gallon at a time
  3. clemsonfor
    I have the pure gas app for my android phone. Y'all with smart phones should get it.
  4. PullinMyPoulan
    PullinMyPoulan
    I have a smart phone but can't figure out how to use it:hair::mad:
  5. Kg461
    Kg461
    Provencal, La.
  6. clemsonfor
    I have learned a lot in the year I have had one. Dex has taught me a lot about them when I have asked!!!
  7. MasterMech
    Compression ratio does not tell the whole story. Engine design, bore diameter, combustion chamber shape all play a part too. My last truck, a 2005 GMC Canyon with the 3.5L I5 had a compression ratio close to 11:1 IIRC and it ran just fine on 87.
  8. nate
    nate Banned
    Palmer, AK
    That chart is about correct for older pre computer stuff. The newer stuff with knock sensors, timed injector spray, adjustable timing, etc can do much more.
    basod, MasterMech and clemsonfor like this.
  9. Tiewire
    Tiewire
    Missouri
    When you take the ethanol out of the gas what does it do to the octane rating. I believe ethanol has a much higher octane rating over gas but you're only losing 10% so maybe it won't matter much. Anybody know?
  10. clemsonfor
    Taking the ethanol out will lower the octane rating.
  11. Tiewire
    Tiewire
    Missouri
    So if you start with 87 or 89 octane how much will the octane be lowered?
  12. mdavlee
    mdavlee
    It will lower your octane. I don't know by how much. I've never seen that part tested.
  13. clemsonfor
    Like mike said...I'm not sure?
  14. Tiewire
    Tiewire
    Missouri
    I was just wondering.
  15. Kg461
    Kg461
    Provencal, La.
    The premix oil Ive heard will also raise the octane
  16. MasterMech
    Other way 'round. Stihl used to have a snippet somewhere about their 89 octane recommendation being based on the fact that the mix oil slightly (and I do mean slightly.) lowers the octane rating of the fuel.
  17. Kg461
    Kg461
    Provencal, La.
    Chad is fixing to test 110 vs 91 octane in my buddies ported 660 to see if high octane benefits these saws
    clemsonfor and mdavlee like this.
  18. Kg461
    Kg461
    Provencal, La.
    I cant agree with that. Oil will impede ignition of the fuel which is what higher octane also does. Resist ignition?
    clemsonfor likes this.
  19. clemsonfor
    Someone posted similar tests on AS on a mastermind saw in the last month I beleive
  20. Kg461
    Kg461
    Provencal, La.
    That was my buddy Ronnie. It was timed cuts but both my MM 461r and his MM 660 is at Chads getting a dyno as we speak. Ronnie and myself have done octane test with timed cuts on AS but wanted to see the test on dyno. So far the higher octane has given both of us slightly faster timed cuts but I know there r variables with timed cuts so thats why we ask Chad to dyno
