Cigars??
Discussion in 'Hobbies and Interests' started by reckless, May 31, 2014.
  1. JimBear
    JimBear
    I am have moved on to see if Betty is as enjoyable as her sister Alice. Betty definitely has a thick as syrup sweetness off the get go. damm near off putting
    J. Dirt and Chvymn99 like this.
  2. JimBear
    JimBear
    I can say that I am not a fan of Betty’s syrupy sweet flavor or her Fat Bottom.
    I had to touch her up once to get to this photo then a couple times after before I kicked her to the curb. I got that syrupy taste almost to the band & a few hints of chocolate from that point on down.
    I had to do some double puffs to keep it going at a few points through out the whole cigar.
    J. Dirt, Hall84 and Chvymn99 like this.
  3. J. Dirt
    J. Dirt
    Just finished a Monte white series. Little late night trouble call gave me some drive time. Wasn’t bad, but tunneled out right at the band. Pretty smooth and peppery.:smoke:
    T.Jeff Veal and JimBear like this.
  4. JimBear
    JimBear
    I really liked the White Label #3 I had.
    J. Dirt, Chvymn99 and T.Jeff Veal like this.
  5. JimBear
    JimBear
    Having one of these while prepping mowers & plotting out where to plant some trees.
    I will probably have a Mint in the afternoon.
    T.Jeff Veal, J. Dirt and Chvymn99 like this.
  6. Hall84
    Hall84
    Hurt
    Did it have a hint of cherry?
  7. JimBear
    JimBear
    Hints of chocolate & cherry, it really smells of chocolate cherry before lighting.
    I am not a big fan of the Wafes, I have a Robusto in the Mint & Red hopefully they are a more pronounced flavor.
    Hall84, J. Dirt and Chvymn99 like this.
  8. JimBear
    JimBear
    Hall84 and J. Dirt like this.
  9. Hall84
    Hall84
    Hurt
    Might have to try one out!!!
  10. JimBear
    JimBear
  11. J. Dirt
    J. Dirt
    The Kentucky fire cured had me second guessing it pre-light….. smells a bit like sour cow chit! What a surprise once lit though!! Nice and smooth good consistent flavor all the way to the end. Hint of fresh cut alfalfa and pecan wood smoke, earthy I’d say. Not much for wrapper flavor. After finishing I had sort of a salty bbq aftertaste.
    My only complaint is not getting a bigger one!! Definitely will get more! C8CE086F-A53D-41E2-BEE8-6C0FC42E0D73.jpeg
    Hall84, JimBear and Chvymn99 like this.
  12. JimBear
    JimBear
    Glad you liked it, pre light sounds a bit off putting.
    J. Dirt likes this.
  13. JimBear
    JimBear
  14. J. Dirt
    J. Dirt
    That would be a cool set up!
  15. Chvymn99
    Getting ready for the GTG…. Smoker Rack for the trailer… so I don’t have the headache of try to solidify with straps….:dex: 3A887518-EEA3-44C6-AF4D-EBB300D1427E.jpeg
    J. Dirt and JimBear like this.
  16. JimBear
    JimBear
    It’s a Diesel but what kind ? It’s a bit blurry. Hopefully you aren’t using diesel to smoke the meat at the GTG. ;)
  17. Chvymn99
    Rage It’s the only Shorty that was in stock for a while.
    JimBear and J. Dirt like this.
  18. Chvymn99
    It’s pretty much done… Hopefully will holdup to Indianapolis & Michigan’s roads…
    AC842872-4C03-43F5-9ACF-6F2FC9619DAD.jpeg D028EEE0-E9E8-475C-AA11-15BEFB5DEA70.jpeg
  19. JimBear
    JimBear
    Never ventured into Michigan but logged a couple thousand miles in Indiana bouncing around in the rig. Illinois & Indiana roads were atrocious.
    Looks solid enough & safe travels.
    The Iowa GTG is going on now over at Chelsea, I have yet to make that one or any other.
  20. JimBear
    JimBear
    These are the Diesel shorties that I have
