Custom garden tractor parts
Discussion in 'Chainsaws and Power Equipment' started by TurboDiesel, Mar 7, 2022.
  1. TurboDiesel
    amateur cutter and brenndatomu like this.
  2. TurboDiesel
    Keeping it running? This machine has never failed to start/run/mow.
    Its been flawless for 26 years.
    Heck! Its even got the original oil in it!:eek:
  3. TurboDiesel
    I do sharpen the blades every 5-10
    years
  4. TurboDiesel
  5. Barcroftb
    Barcroftb
    The Mitten
    Looks similar to the muffler on my kohler powered dingo
  6. TurboDiesel
    I believe kohler is a good engine.
    Some of the later models may have been less reliable in some situations though.
  7. Geoff C
    Geoff C
    NEPA
    I bet you could take the old one off bring it to a muffler shop and they could weld up a new one for you.
  8. Barcroftb
    Barcroftb
    The Mitten
    Mine’s repowered with a kohler command pro. The first Kohler only went 650 hours. I have no idea how it was treated though. Probably roughly. These little machines typically lead a very hard life. 6DA220B3-AE9C-4108-B84A-9F95480767E5.jpeg
    When I was going through the repower search I looked for a new muffler. They make several variations of this same muffler. Yours has a side exit and appears to have longer mounting pipes.
  9. TurboDiesel
    Yep. Same can, different pipe configuration.
    I'm waiting on a reply from Isavetractors. Good chance ima buy a muffler there and adapt it
  10. gwoods71
    gwoods71
    The Mitten
    Looks real close to the Onan 20HP mufflers...
  11. TurboDiesel
    So after days of waiting for an email reply from isavetractors... i called and waited on hold... then after 15mins chose the call back option, and found out they don't carry mufflers.
    :picard:
  12. TurboDiesel
    However they did give me Jack's Small Engine's number to try.
  13. JimBear
    JimBear
    They have lots of stuff, I believe that Northern Tool bought them out or is in the process of. Hopefully that outlet doesn’t turn to chit after being vacuumed up by a mega store.
    Northern Tool + Equipment Acquires Jacks Small Engines
  14. buzz-saw
    buzz-saw
    Ct.
    Well that's not good.
  15. TurboDiesel
    No luck there or parts warehouse. Or troy bilt.
  16. MasterMech
    Not much to those mufflers. Just find one that's 90% of what you need (size and exit location) and fabricate the rest. If you can bend tube, you can fab the inlet piping easy.
  17. Horkn
    But what kind of Kohler? That's the question. It appears to be a v twin, not horizontally opposed. From what I saw, most of these tractors had Kohler magnum engines, which were opposed, not v twins
  18. Horkn
    Courage are the ones to avoid. Kohler's are good engines though, even despite that bad series. Some call them Dis-Courage. 2003-06 models especially
    The rest have been really good for the most part. KT series 1 were splash lubed, not pressurized lube, so they had some issues. Series 2 KT series were fine.
  19. amateur cutter
    If the pipes are good yet, just find an automotive small muffler about the right size and weld the pipes in it. I've got a glass pack type muffler here that would be close.
    Eric VW and Horkn like this.
  20. brenndatomu
    A couple hours with some EMT and a conduit bender you'd have some pretty sweet custom long tube headers....:quad: :D
