Uh......there's more.
Discussion in 'Chainsaws and Power Equipment' started by LordOfTheFlies, Mar 3, 2022.
  1. M2theB
    M2theB
    Central Massachusetts
    The flywheel poles sliding past the coil will create some resistance. I thought if the coil was removed you could eliminate that as a contributor to the notchiness.
    If you can discount that, I’d say there’s an issue with the bearings or the crank run out, or both.
  2. LordOfTheFlies
    LordOfTheFlies
    NY
    I'll try removing the flywheel. Are you saying the magnet is that strong that it would create that resistance? If it spins perfectly smooth with the flywheel off then that's it.
    And btw you said pull the coil and I misunderstand that as pull the rope. I'll disconnect the coil before I take off the flywheel and try that tomorrow. Thanks.
    eatonpcat, huskihl, JimBear and 2 others like this.
  3. LordOfTheFlies
    LordOfTheFlies
    NY
    Ok scratch that I ran out to the garage and sure enough you are correct M2theB . The magnet on the flywheel is so strong on that saw it was immediately clear that it was interacting with the coil.
    Phew! No bearings needed! Woo hoo! Thanks a lot. I really appreciate it.
    Horkn, eatonpcat, Chud and 1 other person like this.
  4. M2theB
    M2theB
    The latter. Remove the coil and leave the flywheel on to turn the crank. See if there’s a difference. If the notchiness is still there, it’s an issue in the rotating element….bearings or crank.
    MikeInMa, Horkn, eatonpcat and 2 others like this.
  5. LordOfTheFlies
    LordOfTheFlies
    NY
    Well it ain't perfect but pretty good. Got most of the aluminum transfer out of the cylinder walls and got most of the carbon buildup on the exhaust port. There was some orange gasket maker on the muffler port which was weird.
    As I'm waiting for the parts for this MS660 I'll start rebuilding the Husky 372xp tomorrow.
    WinonaRail, Tiewire, Haftacut and 4 others like this.
  6. LordOfTheFlies
    LordOfTheFlies
    NY
    Took the first steps to rebuilding the 372xp x-torq today. Scraped the case gaskets off with a razor, sanded lightly, and then used my harbor freight bearing puller which works absolutely amazing.
    Only took a few taps after heating it up the case a little. Woo hoo. Waiting for the parts washer. This thing is gross.
    IMG_20220307_091701.jpg IMG_20220307_091641.jpg IMG_20220307_102550.jpg IMG_20220307_104742.jpg IMG_20220307_105410.jpg IMG_20220307_110017.jpg IMG_20220307_110030.jpg
  7. Wolley
    Wolley
    Pressure washer will work to clean that stuff easy if you have one. I soak in hot water and purple power first.
    WinonaRail, Horkn and LordOfTheFlies like this.
  8. LordOfTheFlies
    LordOfTheFlies
    NY
    I have one but it's winter. Although it's super hot today.....I keep my spigot disconnected until it's consistently above 40 or so. I don't need any hoses bursting.
    I think a parts washer will be nice. I kind of wish I had pulled the trigger on it earlier.
    Just ordered a 20-gallon Jegs and also ordered a submersible pump meant for petroleum based solvents along with the Oriflo washing brush, a remote oil filter mount.
    Now I have to figure out where the hell to put it. I have a lot of dirty saws that need to be warshed.
  9. Chud
    Chud
    Lol, I looked at your pic, and Husky dumpster came to mind. I’m sure you’ll do great getting most of them running.
  10. LordOfTheFlies
    LordOfTheFlies
    NY
    Haha thanks it's getting a bit crazy. And that's the cleaned up version!!
    Horkn, M2theB and Chud like this.
  11. Scotty Overkill
    You win the "YOU SUCK" award for the week.....
    Heck of a score!
  12. LordOfTheFlies
    LordOfTheFlies
    NY
    Thanks!
    Well just to be clear I only scored the opportunity to learn more about a bunch o' different saws and fix 'em up. He didn't give them to me. That said that's still a score in my book. I'm excited to bring these babies back into service and definitely looking forward to the edumacation.
    WinonaRail, Horkn and Scotty Overkill like this.
  13. Scotty Overkill
    It's good stuff either way, I enjoy bringing these saws back to life myself. Most of my collection of saws are ones I've overhauled. None are real pretty but they all get the job done and do it well....
  14. LordOfTheFlies
    LordOfTheFlies
    NY
    Yeah it's super satisfying. I am trying to fill my time with satisfying endeavors and this is certainly right up there.
    The only brand new saw I ever purchased was my first one - the Makita 36v 14" cordless back in Oct-2019. I'm currently also overhauling this 028 from ~1983 for my buddy.... Bought it from FBMP and it was missing a whole bunch of stuff......last thing I was waiting for (or so I thought) was a set of new springs for the clutch.....and got them today. After I put them on the chain brake wouldn't engage and I noticed that the one of the 5mm x .7mm e-clips was missing from pivot point below the handle. I'm glad I caught that before giving it to him because I had tested the brake before after replacing the missing spring......and it had worked then.
    You can see the missing clip below.
    Horkn likes this.
  15. LordOfTheFlies
    LordOfTheFlies
    NY
    Ms660 replacement Meteor piston, rings, wrist pin, circ clips.
    Still waiting for the wrist pin bearing.
    Will reuse the old cylinder gasket with some 1184 on both side. Weird how the gasket doesn't fit around the piston. You have to install the gasket first and then the piston.
    Horkn and Chud like this.
  16. huskihl
    huskihl
    If you use the meteor clips, snip the bulk of those big ears off
  17. LordOfTheFlies
    LordOfTheFlies
    NY
    I'm guessing they have a tendency to unclip themselves and cause a catastrophic failure yah? Thanks for the tip will do.
    Horkn likes this.
  18. huskihl
    huskihl
    The added mass can snap off and also can cause them to come unseated. If oem is the same wire diameter I’d go that route
  19. LordOfTheFlies
    LordOfTheFlies
    NY
    Thanks. Just as an aside the clips that came with the 372xp Meteor piston did not have those big ears......
    Another slightly off topic question - is naphtha safe to use as a solvent in a parts washer to clean chainsaws? Specifically I'm worried about all the hoses and especially the seals. Any experience with it? It would be nice to be able to clean a saw that does not require a complete split up a bit but of course I'd hate for the naphtha to swell up any rubber bits. I'm getting a parts washer and planning on using TSC PSC 1000 as a solvent.
    Horkn likes this.
  20. huskihl
    huskihl
    I use parts washer solvent, but I believe it’s mineral spirits
