  1. Gasifier
    4 degrees Fahrenheit here with a slight breeze. Cold enough the boiler was empty after 9 hours. And the bubblin goo turned on. :rolleyes: Oh well, reloaded and restarted with some lit paper and very small splinters of Pine and Beech that were broke off larger splits. Then loaded Beech and Maple splits on top.
  2. Biddleman
    Biddleman
    River Hills of Pennsylvania
    12/ 65. Having issue with cat. combustor
  3. NortheastAl
    NortheastAl
    Putnam County NY
    10º here with a good stiff breeze. Had a load of coals this morning that I’m burning off with a topping of small ash splits. Had to turn on the furnace for a half hour to get temps up. Heating oil is up to $3.90 a gallon in this part of the state. It’s just crazy.
  4. NortheastAl
    NortheastAl
    Putnam County NY
    That’s not fun. Hopefully, you can get it all squared away. Good luck.
  5. The Wood Wolverine
    10/74. Loading up with all red oak this am.
  6. Backwoods Savage
    Not nearly as cold as predicted overnight (18). The forecasters are into a spell where they can't seem to get it right. It does make me wonder with a big storm on the way. Of course their predictions keep changing. Rai, ice then snow, but how much? At first about 1/10th inch of rain and now 1/2 - 3/4" and snow anywhere from 4 - 12". I just hope we get some melting at first to loosen this ice in the driveway.
  7. lukem
    19 now, headed for close to 50 today. They're saying we could get 2"-4" of RAIN the next couple days.
    Boiler is still working on some hickory and ash from yesterday. I'll load it later this evening.
  8. Cold Trigger Finger
    Cold Trigger Finger
    Easern Central Alaska
    As I did not have my chimney/ ceiling flange installed until part way thru the winter. I was loosing Lots of heat up to the silicone stack boot on the roof . With all the snow we had. I got a doozy of an ice dam at the eaves.
    As the temp would drop , it would Pop or Bang.
    It would drive me nuts as I worked real hard to have an almost perfectly vented roof.
    Live and learn.
    I got the ceiling flange installed and no more increase of ice. Next winter I don't think I will have any ice up there.
  9. Cold Trigger Finger
    Cold Trigger Finger
    Around 5 above
    2 rounds of Black spruce have been in the stove since 11 last night. That's 11.5 hours of burn time . That wildfire killed Black Spruce is some good stuff
  10. Cold Trigger Finger
    Cold Trigger Finger
    The remains of last night's load.
  11. Ward Hoarder
    Ward Hoarder
    West Virginia
    Been colder than normal here. Wood shed is looking sad. 5.5 cord +- used,
    One more cord under lean-to. 2+ yrs.
    CSS at staging area plus 4-5 cord to process.
  12. Cold Trigger Finger
    Cold Trigger Finger
    It's the Cold. When I work outside in the winter I always loose weight.
  13. Stihl Kicking
    Stihl Kicking
    Missouri
    It currently 55* outside, I've been running on one small lone log all night, and it's 87* inside.
  14. Cold Trigger Finger
    Cold Trigger Finger
    0°F ambient temperature
    Winds calm..
    Snowing.
    Fkws in the stove.
  15. NH mountain man
    NH mountain man
    WMNF N.H.
  16. Gasifier
    18 this morning. Yea! Much better. And going to 40s today. :thumbs: Burning Maple now.
  17. Eric Wanderweg
    12 here with beech and mulberry throwing the heat this morning.
  18. yooperdave
    26/72..........and that's about as warm as I want it inside!
  19. Backwoods Savage
    38 this morning. Should get well into 40's today but windy.
  20. Biddleman
    Biddleman
    25/72. Going close to 50 today, with some wind. Ash, with a split of BL for the day.
