Smoker Build…
Discussion in 'The Smokehouse' started by Chvymn99, Feb 6, 2022.
  1. Chvymn99
    I’ve had dreams of a big wood smoker for a long time. And it’s been sitting in pieces in the garage. I bought the metal probably like 8 years ago. Well I’m hoping to get it put together in the near future.
    Buts been a long time since I fired up the stick welder. What rods do I need to buy for this? Here’s a picture of the plate metal.
    SKEETER McCLUSKEY … buzz-saw … WeldrDave …
    Eckie, Barcroftb, eatonpcat and 6 others like this.
  2. Chvymn99
    yep… him too…:handshake:….
  3. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    7018 will give you good looking welds
  4. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    1/8" 90-125 amps DC reverse polarity
  5. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    Lincoln makes some called Excalibur its easier restrike
    Barcroftb, metalcuttr, Camber and 3 others like this.
  6. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    There's a online calculator for sizing your firebox and openings
  7. Chvymn99
    link? My original draft was copied from Lang smokers. It’s going to be a reverse flow smoker.
  8. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    dont have the link handy.....go on smokerbuilder.com and look around im sure its on there
  9. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    i made my tuning plates from 7 gauge and i made them various widths
  10. metalcuttr
    metalcuttr
    western WA
    Good time and good excuse to by a mig welder. A Lincoln Power MIG 210 MP or Miller Multimatic 220 will mig weld, stick weld and DC tig weld. You could sell your old unit to help defray costs. I have the Lincoln 210 as well as two smaller machines, and love it! Use the .035 NR 211 inner shield wire (no shielding gas for this, buy the gas later).
  11. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    it is a good time.....welding together a pit with a stick welder is not a good time.......
    Barcroftb, Chvymn99 and metalcuttr like this.
  12. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    the problem is,if your not experienced it will lead to GIANT amounts of sadness and disappointment..there may be some of that too with a wire feeder but probably less :rofl: :lol:
  13. Chvymn99
    I've got a big Miller at work. If it becomes too much of a issue, I’m sure I can talk to the boss about borrowing some wire.
    But I’ve got these two old timers. And the last time I used it for welder up hardware for my jeep. It did a good job.
    Barcroftb, metalcuttr and eatonpcat like this.
  14. Chvymn99
    :whistle:… always retraining oneself curve…
  15. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    tombstones....i got a couple too
    Barcroftb, metalcuttr and Chvymn99 like this.
  16. The Wood Wolverine
  17. metalcuttr
    metalcuttr
    western WA
    I've done a lot of welding with the old tombstones. Probably every farm or ranch had or has one and tons of 6011 rod burned on them. They get the job done. One advantage of the wire feed is the thin metal welding capabilities with gas shielding. Not trying to push you in any direction. Just introducing the opportunity to maybe upgrade and gain expanded capabilities in the process. We do like to spend other members money here at FHC and it doesn't always have to be chainsaws! Wish you the best of success in your smoker build!
  18. Chvymn99
    I have a Lincoln ProMig 135 for all my small jobs…:handshake:…
  19. Chvymn99
    Note to myself:
    Main smoker body is 48.75” long and 30” ID
    Wood Box 19.5” cube
    1/4” steel
