Initial carb settings for a Homelite XL automatic top handle
Discussion in 'Chainsaws and Power Equipment' started by foragefarmer, Aug 17, 2014.
  1. foragefarmer
    foragefarmer
    Central, Virginia
    Anyone know or I know there are a bunch of these saws out there do you know what your saw settings are? I bought a 5 saw lot off CL and this was one. Solved the no spark issue, bad wire connector. Saw fired and wants to run, but is running insanely fat. High screw was 7 turns out and low was 6 turns.
    @MasterMech don't you have one?
    The Poulan 306A was similarly messed with and I tweaked for a long time to get it dialed in close, a base point would be nice.
  2. cnice_37
    cnice_37
    Just try 1 and 1 and go from there
    foragefarmer likes this.
  3. foragefarmer
    foragefarmer
    Central, Virginia
    That is where they are now. Piddling with the pull cord, and hoping for a better response.
    cnice_37 likes this.
  4. AmarilloSlim
    AmarilloSlim
    Amarillo
    Mine is set slightly under 1 1/2 & just over 1 3/4 if I remember.
  5. MasterMech
    I have a Super 2 which I believe is similar. It's not running at the moment so I have no idea if the carb settings are good or not!
  6. foragefarmer
    foragefarmer
    Central, Virginia
    No worries, I have concluded it needs a carb rebuild. The XL and Super 2 would seem to take the same rebuild kit. You just have the interesting double trigger on yours. Old school hybrid tech.
    The XL is a neat tidy design. Cheap but neat and tidy. I also tinkered with a 192c this weekend, not neat and tidy. I realize that 30 years of safety and emissions requirements separate them but holy train wreck.
  7. cnice_37
    cnice_37
    If by neat and tidy you mean "take the entire saw apart" to replace anything...
  8. MasterMech
    Lots of early top-handles were like that. Split the cases and puke the engine out on the bench. Go through the issues, do some preventative replacements and re-assemble. Good times. :D
  9. foragefarmer
    foragefarmer
    Central, Virginia
    10 screws and it is totally apart. What is not to like?
    MasterMech likes this.
  10. cnice_37
    cnice_37
    About 8 screws too many! Haha, just a lot of dis-assembly to inspect a fuel line or clean a carb.
  11. foragefarmer
    foragefarmer
    Central, Virginia
    Don't go near the 192 then! Inspecting a fuel line? Forget about it.:whistle::D
    MasterMech and cnice_37 like this.
