Anyone know or I know there are a bunch of these saws out there do you know what your saw settings are? I bought a 5 saw lot off CL and this was one. Solved the no spark issue, bad wire connector. Saw fired and wants to run, but is running insanely fat. High screw was 7 turns out and low was 6 turns. @MasterMech don't you have one? The Poulan 306A was similarly messed with and I tweaked for a long time to get it dialed in close, a base point would be nice.
I have a Super 2 which I believe is similar. It's not running at the moment so I have no idea if the carb settings are good or not!
No worries, I have concluded it needs a carb rebuild. The XL and Super 2 would seem to take the same rebuild kit. You just have the interesting double trigger on yours. Old school hybrid tech. The XL is a neat tidy design. Cheap but neat and tidy. I also tinkered with a 192c this weekend, not neat and tidy. I realize that 30 years of safety and emissions requirements separate them but holy train wreck.
Lots of early top-handles were like that. Split the cases and puke the engine out on the bench. Go through the issues, do some preventative replacements and re-assemble. Good times.
