  1. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    My domestic hot water is off the boiler other than for that and as backup if the stove has pooped the bed and if we go somewhere for a couple of days or if I go on the generator.
  2. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Yep, that jet stuff is kero.
    So you were trying for white tail up in T7 and T8 range 11. I can sit on the front or back deck and see them critters if I want to get up early enough. I hunt garden varmints for the most part these days. Sometimes they are in a trap and sometimes not. Liked bird hunting better than deer, but I haven't seen a ruffed grouse or a rabbit since I arrived on this lot. There should be some of each.
    I used to burn anthracite in an old refurbished gravity hot air furnace, it never was cold it that big old house even when outside was between 20 and 30 below or the power was out.
  3. ivanhoe
    ivanhoe
    Northern Ontario
    Long time no voice! I finally put the Harman Accentra back together with new board & combustion motor and still having issues. The Fahrenheit is put back together and waiting on installment. Still contemplating on vent for it(multifuel or not venting). We've been burning some canola seeds at work in the bark/sludge boiler and wow, it's dynamite(very, very volatile fuel). I cannot say too much for this summer, rain & cold as we speak. Pellet stash not been tended yet.....
    343amc and will711 like this.
  4. savemoney
    Don't you have someone who can get that fixed for you? My dealer would be right here as get it right. Of course, my nephew does work for him has a service tech.
  5. DexterDay
    I'd go multi fuel. Just for piece of mind. Even standard pellet vent will take a beating when just running pellets (if stove isn't running right).
    So the one time cost is worth the piece of mind, IMO.
    Keep us updated on the install :)
    savemoney and slvrblkk like this.
  6. mithesaint
    mithesaint
    NW Ohio
    I'm with Dex. Not sure if you have access to corn or not, but corn was around $125/ton around here last time I checked, so I think I'll be burning a fair amount of corn this winter.
    DexterDay and savemoney like this.
  7. will711
    will711
    Pocono Mts.
    Nice to hear from you again :D What issues are you still having?
    DexterDay likes this.
  8. Lousyweather
    Lousyweather
    ohhhhh....the joys of working Sunday, and on Tax Free weekend, no less........unmanageably busy yesterday.......stove total to follow after today......any guesses what a busy weekend is like in this industry?
  9. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Well got a call this morning from the folks that are going to deliver my pellets on Tuesday wanting directions and land marks. The boss told them that after they drive by and can't find it to give us a call and she'll send me down to the end of the driveway to flag them down.
    All I have to do now is remove all of my equipment for yard word out of the garage.
    savemoney likes this.
  10. ivanhoe
    ivanhoe
    Northern Ontario
    New dealer is way out of question, don't ask why. Parts bought online and DIY! No it's not my workmanship.....
  11. ivanhoe
    ivanhoe
    Northern Ontario
    3 blinks of death. Changed the dip switch setting no.5 and still 3 blinks, ggrr! Using the old ESP which was working before the board was switched over.
  12. ivanhoe
    ivanhoe
    Northern Ontario
    Double the amount of $ is a stumbling factor but might still be a go. When I get there which is soon it will be decided.
  13. will711
    will711
    Pocono Mts.
    That's not good, I wish I had the answer for you. Maybe Lousyweather can help you he's a stove dealer .
  14. Lousyweather
    Lousyweather
    the 3 blink, huh? Not wanting to beat the dead horse, but whats the wire color? Also, check the connection to the board. Could simply be a coincidence, but maybe the probe is kaput? Red wire ESP= switch 5 ON, black wire ESP = switch 5 OFF......other than that, the only way to tell is to throw a DDM on the thing.
    will711 likes this.
  15. Lousyweather
    Lousyweather
    also, just for the heck of it, whats the series board you have, and the switch settings of ALL the switches? The board will have the part number, followed by a letter- I wanna know what that is. Keep in mind that there are at least 6 different series of that same board, and some switch settings aren't the same.......TYPICALLY, the Accentra FS will have:
    1. on
    2. off
    3. on
    4. off
    5. dep on probe (see above)
    6. on
    7. off
    8.off
    Keep in mind this is BOARD DEPENDENT, and stove dependent! New boards come from HHT with switch 5 usually set to ON, for the stock red wire probe. Older stoves very well could have the old black wire probe, and wont function correctly id set incorrectly.
  16. Lousyweather
    Lousyweather
    anuder thing to check on the Accentra FS and the XXV is the wire bus connection to the board....since they are mounted on a door that moves, if the wires are too tight, they can get partially unplugged, causing weird issues, when the door gets open/closed.
  17. will711
    will711
    Pocono Mts.
    You're a good man, :thumbs: lots of helpful info there hope this solves his problem.
  18. DexterDay
    I'd think 10 stoves is a lot? Did you sell a lot of pellets as well?
  19. ivanhoe
    ivanhoe
    Northern Ontario
    The board I toke out was 3-20-05374 rev C and I put in 1-00-05886 from Earth Sense Energy Systems. I would have to open the door again to peek at the real number. Crazy thing is the distribution blower, exhaust blower stays on even when the setting is on off along with the periodic auger motor coming on for 1 second or two. My other board I had the exhaust blower would stay on indefinitely even when I tried a new red wire ESP. I have the black one.
  20. ivanhoe
    ivanhoe
    Northern Ontario
    It's those settings but for the black wire. On the paper sent along with my new board, it shows 3-20-05886E.
