Parents bought an insert, I have question or 2
Discussion in 'Modern EPA Stoves and Fireplaces' started by The Wood Wolverine, Dec 31, 2021.
  1. Locust Post
    No help on a small amount I bought a whole bat of it at Lowe's because I had other places to use it as well.
    wildwest, Horkn and brenndatomu like this.
  2. Horkn
    I just stuffed the ceramic wool insulation up into the throat of the chimney and also used a similar idea, except with large SS hose clamps to keep it at the top. I would think metal would be best, but it's probably kinda a pita to work in that area. I think a 2 piece thin steel sheet with a half circle at end will work. One of these days I'm make one for mine. I haven't had any issues by not having the block off, but it will be best to use one. I don't notice any drafts, but I have a fire pretty much 24/ 7 so a draft would be tough to notice.
  3. g60gti
    g60gti
    NY West
    I went with a 5.5” liner in my installation. I could of fit a 6” but wanted to insulate so I went with 5.5” and whatever the thinnest insulation was(.25 maybe?). It drafts extremely well and I’ve had no problems. It’s approximately 23’.
  4. brenndatomu
    I got a few pieces from a local insulation installer...he had a stash of leftover pieces...heck, IIRC it was free too. (brothers buddy)
  5. wildwest
    Thanks, I'll call around tomorrow. My roofing contact does not use what I'm looking for so I'll try insulation companies and the stove dealer I buy pellets at, then try to corral my 'roofing contact' to pick it up lol.
  6. The Wood Wolverine
    Got the insert installed today. Not difficult at all. Dad stuffed the fireblock insulation up in and around the liner at the base and some around the top. Started small paper fire first and everything looked good, so we went ahead with a wood fire. A bunch of pine kindling and then two small piece of mulberry. I brought him a big arm full to burn. All seems well.
  7. g60gti
    g60gti
    NY West
    Looks good. What did you end up doing with the liner?
    Horkn, Eric VW, Chvymn99 and 3 others like this.
  8. The Wood Wolverine
    5.5” stainless flex pipe.
    Can anyone advise on thermometer location to gauge burn temps? We have it here but I’m skeptical.
    If I put it in the middle, the blower outlet will be going over it.
    Air intake is set at minimum and stove is cruising right above 500 at that spot. Should I get something to connect to the liner a few inches up from stove connection?
    Horkn, Eric VW, Chvymn99 and 2 others like this.
  9. g60gti
    g60gti
    NY West
    Nice. I went 5.5 too some could insulate. Sorry I’m no help on the thermometer, I’ve never had one on my insert. Thought about it once but never did get one.
  10. Chvymn99
    Looks nice. Nice job!:handshake:
    Horkn, Eric VW and The Wood Wolverine like this.
  11. Horkn
    With an insert, that's about what you can do for thermometer placement.
    Looks nice, looks like it is choochin' nicely.
  12. brenndatomu
  13. Locust Post
    Looks nice
  14. The Wood Wolverine
  15. ReelFaster
    ReelFaster
    S.Jersey
    Looks great, nice job! Reminds me of when I did my insert install...........It was a really fun project
    My insert don't stick out very far this is where I keep my thermometer
  16. The Wood Wolverine
    wildwest, brenndatomu and ReelFaster like this.
