File vs Electric Sharpening...
Discussion in 'The Wood Pile' started by The Axeman Commeth, Jan 20, 2022.
  1. jo191145
    I have three of the $100 models. They’re steel. I can’t imagine overheating or burrs. Course I don’t jam them in there and try to remove half a tooth at a time either. :)
    Now the cheap Chinese wheels that came with the machine, yeah, molten slag is easy to make and burrs the size of fingernails.
  2. Screwloose
    I'm interested in knowing where you found the steel wheels. I could use them for profiling chip breakers in plastic turning tools.
  3. jo191145
    Know sumptin, You’re absolutely right. Just went and checked and they are aluminum. Doh!!
    Found this for ya
    CBN Chainsaw Sharpening 5 3/4" Disk, 7/8" Arbor, 1/8" Thick
  4. The Wood Wolverine
    Agree'd. This and the fact that I have arthritis-like symptoms after vigorous use of fingers/hands, both of which led me to seek out a grinder. I should have got one long ago! No regerts. Lol.
    3D722003-19D4-490A-91D8-5300B5BFCE70.jpeg CBB6F18D-50A6-4922-ADE8-1CBD2EDF7D9E.jpeg
  5. jo191145
    No wonder you enjoy noodling so much
  6. The Wood Wolverine
    :yes:
    Since getting it, when I accidentally bump ground or a rock I'm a lot less bummed out than I used to be. I just carry spare loops, swap them out and keep cutting. So in that aspect, it has increased my productivity. I never leave the house without a fresh ground loop on my saws. If they fall off a little in cut speed, swap it out.
  7. jo191145
    I can see that. That’s pretty much how I do it too. Never been a hand filer. Only difference is the mental aspect. I’m just fixing a factory profile. You created your own. I think I’d enjoy grinding more that way ;)
  8. Backwoods Savage
    I grew up only knowing hand filing and almost always done right in the woods. After my hands went bad I was talked into a dremel with stones and it worked okay but one has to be super careful with them. A couple years ago I did get the Stihl sharpener and found I can once more do the hand filing because I can get hold of the tool. It just takes me longer but it gets done.
  9. Screwloose
  10. RGrant
    RGrant
    Connecticut
    I have a cheap file kit. I don't do it right yet, my saw pulls to the side. But I'm not going to get it right by not trying.
  11. jo191145
    I just bought a cheap Husqvarna kit myself. Mostly for the different style raker gauge inside. There’s definitely times just a small touch up is in order. Hand filing is great for that. When I cut a rock in half that’s different.
  12. The Wood Wolverine
    Uneven cutter length can lead to that if you use this style tool to file your depth gauges.
    Switch to a progressive style and you will cut straight again (assuming your bar rails are true).
    [​IMG][​IMG]
    Just make sure you get the right one for your pitch chain.
    Really good info here: http://gepkolcsonzo.eu/wp-content/uploads/2012/01/complete-book.pdf
    About pg. 16 it explains more detail of depth gauge maintenance.
  13. Dok440
    Dok440
    NorCal
    That things a monster! I've seen one at a saw shop once but don't know anything about them. Very impressive!
  14. chris
    that is a grinder for chisel profile, common name square grinder, unless you re-profile the wheel it does not do round style teeth - not sure if even re-profiling the wheel would accomplish that or not. On the other hand the common shop saw style grinders are not any good for a proper chisel profile. Drawback is you have to go back at some point and clean out the gullets as a second operation when using a sq grinder, and of course still the depth gauges to adj.
  15. gwoods71
    gwoods71
    The Mitten
    I have always Sharpened by hand, but i had a 20% off for harbor freight, and a couple chains were cutting curves (GOOD CUTS, BUT CURVES), so I figured I would try their sharpener on the MS 290.
    Stay tuned...
    amateur cutter and Screwloose like this.
  16. Oakman69
    Oakman69
    Mechanicsville
    I use this little piece of crap and once I learned it I can sharpen 3 chains more accurately than by hand. Still love bybhand tho. It really connects you with your saw. U know what I mean?
    Screwloose and amateur cutter like this.
  17. Mag Craft
    I have entered some race chain contests and I have done ok. I only entered chains that were ground on an electric grinder.
    But even though I did pretty good the guys who really know how to file their chains always took first place.
    So, if you are good with a file, it will always cut faster than one done on a machine. I just prefer using a machine myself because it is so easy, and I can get consistent results.
