Leveling feet for a Fisher Insert
Discussion in 'Non-EPA Woodstoves and Fireplaces' started by jewilson, Jan 16, 2022.
  1. jewilson
    jewilson
    Fancy Gap Virginia
    Handshake to you all. Heavy snow here in SW VA. I’m ready to hook up my insert as soon as the weather breaks.
    I removed the gas logs and noticed the brickwork on the floor of the hearth is lower than the rock outside. I think it will be uneven when I slide the insert in place.
    Do any other you know of a source for leveling bolts for a fisher insert.
    Thanks for your help. [​IMG]
    WeldrDave and stuckinthemuck like this.
  2. stuckinthemuck
    stuckinthemuck
    This is not an answer to your question, but could you throw a couple small pieces of plate steel of the appropriate thickness under it?
    Warner and jewilson like this.
  3. lukem
    Stack up some washers on any old bolt until you get it where you want it.
    RGrant, jewilson and brenndatomu like this.
  4. jewilson
    jewilson
    Fancy Gap Virginia
    I found a solution that works perfectly. I have a 30 year old craftsman table saw. I used two of the feet off of it. Cleaned the rust off of them and ran a die down the threads. Also chased
    the threads on the 1/2x13 threads on the insert. Looks just like what is pictured in the manual and works very well.
    stuckinthemuck likes this.
