  1. Cold Trigger Finger
    Cold Trigger Finger
    Easern Central Alaska
    Anyone wants to be in winter, just go buy a good Strong snow shovel and fly into Fairbanks.
    You will get more than your share of Winter!!
  2. Redneckchevy
    Redneckchevy
    Ladysmith, Wi
    That's the corn silage pile, it's on a blacktop pad, then covered with a heavy plastic made for silage piles Then for weight to hold it down and keep it good a weighed tarp then covered in tires, we only uncover and cut plastic back about 10 ft at a time to keep it fresh.
    The pile is about 20ft tall.
  3. Redneckchevy
    Redneckchevy
    Ladysmith, Wi
    I load, mix and feed out 5 loads of feed a morning, in the mixes there is around 40,000lbs of corn silage total per day.
  4. Cold Trigger Finger
    Cold Trigger Finger
    How many cows do you feed ?
    40 k lbs is A LOT of feed each day !
  5. Redneckchevy
    Redneckchevy
    Ladysmith, Wi
    And That's just the corn silage in the mixes :rofl: :lol:
    Today was 57,770 lbs to the milking cows, 7400 lbs to the dry cows and 12,000 lbs to the heifers.
    Takes me about 5 hours every morning to feed.
    They are milking around 500 cows.
  6. yooperdave
    I was expressing my surprise at the temperature since it was not forecasted at all. This one was missed by 25 or so degrees warmer for an overnight low.
    I am only too familiar with cold temps and working in those conditions......years of going in to work leaving the house at 4:30 a.m. with -40 (I think -44 was the worst) and not being warm until that evening13-14 hours later.
    Looking back on it, I wouldn't even think about going in for those conditions now-a-days.
    That boss was a SOB
  7. Locust Post
    21/72 just got a load of red oak and ash going for the evening. 10 predicted for overnight. Muzzleloader comes in tomorrow and I would love to go but with my knee torn up I will probably load the stove in the morning and look out the window.
  8. Gasifier
    11 degrees Fahrenheit right now with a steady breeze out there. :shiver:
    Wood Gun filled up and no leaks at valve. Fired up and slowly coming up to temperature! Mix of Maple and Beech going now. Let’s hope everything goes smoothly and we don’t have any air problems.
  9. HDRock
    I like my 4 inches here much better :D oh yes it's cold outside :shiver::BrianK:
  10. JimBear
    JimBear
    Osage, Oak & Cherry
  11. JimBear
    JimBear
    Calling for 14* tonight & 35* tomorrow. I am going to burn a load of Beech tonight.
  12. NYCountry
    NYCountry
    Mohegan Lake NY
    14f here with some nasty wind that’s blowing this snow around. 70f inside the jotul is cruising
  13. theburtman
    theburtman
    Apple and hard maple
  14. jmb6420
    jmb6420
    Grand lake, Oklahoma
    Just down to 29f tonight. Half load of red oak before bed. Since I insulated I’m having to burn smaller fires. Usually just 2 small fires a day. It can be 15f outside and the house will maintain temp overnight. It’ll drop about 4-5 degrees overnight with no fire.
    Mike in Okla
  15. Slocum
    Slocum
    North Central Indiana
    12 and 72. Red oak burning. Up in the 30s tomorrow. Bummed about that, I want some winter.
  16. Sourwood
    Sourwood
    Popcorn, IN
    Another very cold night. Fireplace going, watching True Grit. Will take a break in a bit to load the overnight.
  17. Gasifier
    Wood Gun boiler and big buffer tank up to 170+. It’s working! Soon to be 190!:woodsign::fire:
  18. Erik B
    Erik B
    Western Wisconsin
    Hope your fix hangs in there:handshake:
  19. amateur cutter
    18F clear and calm, another perfect winter day and evening I was stuck working. Locust out and Oak in.
  20. Eric Wanderweg
    25 heading to the mid teens by sunrise. Going buffet style overnight tonight with a mix of apple, beech, black birch, yellow birch and black locust. Hopefully between all that I’ll have some coals to wake up to :thumbs:
