Recommend a replacement, 14” 30-40cc limbing/trimming
Discussion in 'Chainsaws and Power Equipment' started by RustyKnifeUSMC, Dec 19, 2021.
  1. EODMSgt
    EODMSgt
    White Mountain Region, NH
    It's been a PITA to start since day one new out of the box, so I don't think it needs a carb rebuild. Doesn't have much mileage on it since I usually just grabbed a different saw since I didn't want to deal with the hassle.
  2. Lehman
    Lehman
    Minnesota
    Ok I missed the bought new part, ever bring it back to see why? Can’t remember but does it have a primer?
  3. Lehman
    Lehman
    Minnesota
    Still a clam shell saw, if I were him if the rings don’t look stuck and it feels like enough it probably will run. I don’t have high faith in gauges they can fail slowly and you don’t even know it.
  4. Lehman
    Lehman
    Minnesota
    I’m sure this site needs something special done to load a video like the others but if it was easy I’d show a video of my personal 194t after it had some muffler work and a timing advance. I do the same stuff to the tree service saws from when they’re new and they’ve held up well so doesn’t see to be any down side of modding the 193/194 except a slightly louder exhaust.
  5. buZZsaw BRAD
    i really wasnt but for $125 i opted to buy it.
  6. buZZsaw BRAD
    you can load videos although ive never done it, just pics. Calling Eric VW as he can walk you through the process.
  7. M2theB
    M2theB
    Central Massachusetts
    you need a hosting service, like YouTube
  8. Eric VW
    M2theB to the rescue!:D
  9. amateur cutter
    If it were me, I'd buy the Echo in the size & style you like, get it ported by someone reputable & never look back. They make wicked fast little saws for way less money, & they last really well. I've run a few top handles & a lot of my climbing friends run them. Please keep in mind that my saw fleet is Stihl. The Echo saws impress me.
    RichE23ACR, Horkn, EODMSgt and 2 others like this.
  10. RustyKnifeUSMC
    RustyKnifeUSMC
    Missouri
    Being new to this site do we have any resident members who port saws? Or is there a list or old threads that have information on places to send saws out to get porting, modifications, etc.?
  11. JimBear
    JimBear
    Ol’ Sausage Fingers can help you out.
    huskihl
  12. huskihl
    huskihl
    I recommend the Echo 2511P. Rear handle that weighs about 5.5 lbs. Eggshooterist and Barcroftb each have one.
    I know it’s only 25cc, but they’re so nice for light work
  13. huskihl
    huskihl
    Makita has a couple semi/pro construction candidates too but it’s tough to recommend a late model production saw from a company that’s halting their gas saw lineup.
  14. Lehman
    Lehman
    Minnesota
    Didn’t know the 2511 rear handle was available here, I would have added it to the list because even just a timing advance and muffler work makes them cut but he didn’t want a top handle. Personally not a big fan of the 355 I think it is. The direct competition to the 201 whatever that one is but maybe because I didn’t run it enough
  15. Yawner
    Yawner
    Louisiana
    I have an Echo 2511, really cool saw. But also have a Stihl ms200. The latter is a far, far stronger, as it should be. Every time I use the ms200, I am reminded how incredibly strong it is for its size. The 2511 is fine for limbing small stuff but the ms200 will buck much larger logs with ease. Mine is muffler modded. Ported would be even better.
    Horkn and amateur cutter like this.
  16. Eggshooterist
    Eggshooterist
    Erff
    I absolutely love my 2511 P. The top handle was great too.
  17. Eggshooterist
    Eggshooterist
    Erff
    I have two saws ported by Kevin, huskihl and I can say they run strong and he is an outstanding guy to deal with. He keeps you in the loop with pictures of his progress ect. I plan on having two more saws ported and Kevin will be doing those as well.
  18. Eggshooterist
    Eggshooterist
    Erff
    There is a rear handle 355 as well called a CS361P
  19. Eggshooterist
    Eggshooterist
    Erff
    This how my Ported 2511 runs. As stated above, Kevin, aka huskihl ported this.
  20. buZZsaw BRAD
    When ported and MM what do you guesstimate the power level to be Kevin?
