Engine overheat help
Discussion in 'Everything Else (off topic)' started by Well Seasoned, Dec 3, 2021.
  1. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    Good luck with this Brian! Couldn’t happen when when it’s warm outside :doh:
    Chvymn99, Horkn and Well Seasoned like this.
  2. Well Seasoned
    Nope, but I'd be complaining then too!
  3. Warner
    Should be a available at any parts store.
  4. Well Seasoned
  5. Creekin
    Creekin
    Manitoba
    Bear in mind that those leak detectors are not always accurate, should be, but sometimes false negatives happen
    I've had mixed results with them
  6. tree killer
    tree killer
    Central me
    That’s it. Just got back from town. Make sure you don’t suck up any anti freeze or that batch needs to be dumped and refilled with new.
  7. Well Seasoned
    I did the pressure test and i didnt lose any pressure. I took the cah for a spin after running it a little while, no overheat, cabin had heat but then stopped. I'm sure it wouldve overheated if i kept going
    Jack Straw, brenndatomu and Horkn like this.
  8. Creekin
    Creekin
    Manitoba
    Try running engine with the pressure gauge on without any pressure, watch the gauge needle closely and see if it twitches, may not, but see if it builds pressure quickly
    Also, must be done on cool engine with all air purged to give accurate info
  9. Creekin
    Creekin
    Manitoba
    Does the cap test good?
    Generally the heat in the cab goes away from an air lock in the heater core,
  10. Well Seasoned
    Engine was cold.... really cold. I will try that method and report my results.
    The Subaru dealer didn't have one when i called. I am planning on ordering one as well as an oem thermostat. I still need to research the k&w goop
  11. Creekin
    Creekin
    Manitoba
    You bet! Keep us posted!
    Jack Straw likes this.
  12. brenndatomu
    Horkn and Jack Straw like this.
  13. Well Seasoned
    Would the engine overheat with a heater core block? Can i disconnect the hoses going through the firewall and flush with a garden hose or no?
  14. Well Seasoned
  15. Warner
    Yes you can flush the core. I doubt it would cause an overheat but I literllay have 0 experience “feeling the love”
  16. Creekin
    Creekin
    Manitoba
    I should try some of it on my buddies duramax, he's not really wanting to do the head gaskets on it
    Horkn, brenndatomu and Well Seasoned like this.
  17. Well Seasoned
    I've read the directions as well as a mechanic's suggested way to use the stuff. Reviews say 80% of the time it works
  18. Creekin
    Creekin
    Manitoba
    You can try it, hets messy though
    Horkn, Well Seasoned and brenndatomu like this.
  19. Creekin
    Creekin
    Manitoba
    I'll give it a shot next week, i think book time on the dmax is something around 30 hours
  20. tree killer
    tree killer
    Central me
    That’s the stuff right there. Just time consuming, mostly in the house drinking beer and waiting for it to set. Drain, remove t-stat, flush fill with h20 and sealer run to temp and let sit 24 hours or something. Drain, fill, install t-stat, and run to temp. Should be good to go. Possibly need a second dose but rarely.
