How do you maintain the best catalyst performance?
Discussion in 'Modern EPA Stoves and Fireplaces' started by timusp40, Nov 2, 2021.
  1. fire_man
    fire_man
    North East MA
    Yea it was a combination of wet cottonwood and an old dying cat combined. Not one of my better burns that day :rolleyes:.
    TurboDiesel and Backwoods Savage like this.
  2. Highbeam
    Highbeam
    I get 24 burn times with a full load at a lower setting. Doug fir or other lower btu wood.
    A complete cycle is full it with wood and let it burn down to just coals before loading another full load. This in contrast to those folks that chuck in a new split every couple of hours.
    Hoytman and TurboDiesel like this.
  3. Backwoods Savage
    That's a big maybe. :rofl: :lol: :rofl: :lol: :rofl: :lol:
    fire_man and TurboDiesel like this.
  4. TurboDiesel
    I've tried throwing a couple splits in to keep the fire going, seems to build up more coals that way.. (too many)
    Backwoods Savage and Highbeam like this.
  5. TurboDiesel
    I fought to get the fire going last night after burning up a bunch of cardboard, so today i pulled the cat out and cleaned it.
    Not sure you can tell from this pic, but i cleaned half then took a picture.
    Before
    Backwoods Savage and Hoytman like this.
  6. Hoytman
    Hoytman
    OH
    Looks like you cleaned the left side in the top picture.
  7. Hoytman
    Hoytman
    OH
    Not sure which stove that CAT goes into, but the way it is made it looks like it just lifts out and drops into place. The gasket must lay in the stove and simply outline the frame of the CAT? At least it looks that way without seeing the rest of the stove. Beets trying to wrap a gasket around a CAT them finessing it back in place.
    Is it typical to see the inside of a stove all glazed up using one of these? I hope not. I’d like to avoid that with at least 3 year seasoned wood and keep the inside of my stove, stove pipe, and chimney clean.
  8. Hoytman
    Hoytman
    OH
    Isn’t that a way to help rid a stove of excess coals? I thought so. I’m talking about after the coals build up though...throw in one or two small splits to help the coals burn down.
    Backwoods Savage and TurboDiesel like this.
  9. Canadian border VT
    That’s a Woodstock Ideal steel cat yes it sits in a hole on the “sled” and a lever pulls it overs smoke path when stove is to temp.
    pulling cat 1 and putting in spare is 2 minute, no tool , job that can be done when stove is in coaling stage.
  10. Canadian border VT
    Yes, but I think TurboDiesel was talking about hot loading. Refilling stove quickly before bed which can lead to coal build up and probably done with a high BTU wood
    burning down coals is best left too lighter BTU woods like pine and basswood
  11. Highbeam
    Highbeam
    When run on lower outputs, where a cat stove is cleanest and most efficient and where most folks run their stoves most of the time, the firebox can “glaze up” or get dark deposits. The cat loves eating that heavy, slow moving, smoke and the roof of the stove will be brown and of course the cat is eating the smoke so chimney deposits are reduced.
  12. Highbeam
    Highbeam
    Only if you throw in a small split and leave the intake wide open. Some folks, to keep a stove burning all day at low output, will chuck a split in every so often just to keep a small fire going.
  13. TurboDiesel
    Yes, yes. Yes. Yes and yes.:handshake:
    Don't use oak to "burn the coals down"
  14. Hoytman
    Hoytman
    OH
    Now I know what I can do with the large basswood trees next to my house that need cut down. Two have pretty good logs in them.
  15. Backwoods Savage
    It can help but only if you use a couple really small splits. Otherwise you simply add to the coals. A much better way (for us at least) is to watch the stove top temp and when it drops to around 325-350 we open the draft all the way. If the coal pile is real big I may stir the coals a couple times as it is burning down as this will speed things up.
  16. fire_man
    fire_man
    North East MA
    I use to have a terrible problem with excess coals in the Fireview but the real problem was it was undersized for the house. Fast forward to the replacement stove (Progress) and now we have zero problems with coaling.
    When we had the coaling problem we did exactly like Backwoods said and opened up the draft when the stove hit around 350.
  17. Gark
    Gark
    SW Michigan
    I tried all the previously listed things with some success. Then came across a process written by Sud-Chemie (they used to make wood stove cats) for ceramic cats that happens to work stellar with our stainless cat in the IS. Trying to figure out how to attach a PDF now….
    The chapter is called “ VI. Major Cleaning Procedure
    For Süd-Chemie’s Catalytic Combustor”
  18. MikeInMa
    I find the gasket is all crumbly when I remove the cat. I bought a roll of cat gasket material and replace as needed.
  19. Rearscreen
    Rearscreen
    Posted this before but thought it was appropriate.
  20. TurboDiesel
    Same here. Even the IS had a little trouble with excess coals.
