What's on your bench now?
Discussion in 'Chainsaws and Power Equipment' started by Czed, Jun 29, 2020.
  1. huskihl
    huskihl
    7 psi both ways is enough. Be careful when you get up north of 10 a little bit on pressure. I have played around with it a little bit and at 13 or so it prolapsed a seal and spit the spring out
    Mag Craft, MAF143, M2theB and 2 others like this.
  2. M2theB
    M2theB
    Central Massachusetts
    I think I had that but I’ve got to where parking on 10 is easier to track
    Physics aren’t justified but the accounting is
    Horkn, MAF143 and huskihl like this.
  3. huskihl
    huskihl
    Makes perfect sense. Lol
    Horkn, MAF143 and M2theB like this.
  4. M2theB
    M2theB
    669ECBF8-6B35-4933-8D80-82D26895870B.jpeg 4120864D-2C4F-47E9-92B6-618E9524FE7C.jpeg B26F283E-6E48-472D-A5FF-3F88623B76AA.jpeg 4C6614A5-9E51-4CCE-A886-EC00C4601F8F.jpeg
    An air leak is one way to lean out a saw. Took care of that. It was minor at that on the vacuum side.
    On the put back I went through the brand new looking AM carb first. Hoping this was the major issue.
    Horkn, LordOfTheFlies and Chud like this.
  5. huskihl
    huskihl
    Horkn, LordOfTheFlies and M2theB like this.
  6. M2theB
    M2theB
    someday I might smarten up and look there first!
    Horkn, LordOfTheFlies and huskihl like this.
  7. LordOfTheFlies
    LordOfTheFlies
    NY
    That's due to a lack of replacing the fuel filter regularly, right? Or perhaps a fuel filter that popped off. Is cleaning out a carb something that should be done on a schedule or realistically do most people just run them until something like this happens and then clean them?
    Sandhillbilly, Horkn and M2theB like this.
  8. huskihl
    huskihl
    There’s no hard fast rule, but typically it’s from when the fuel filter falls off or breaks off the line inside the tank and the saw continues to suck everything from the gas tank into the carburetor. But Mike had it happen on a brand new 572 with everything still intact
    Horkn, M2theB and LordOfTheFlies like this.
  9. LordOfTheFlies
    LordOfTheFlies
    NY
    I had some sawdust/bar oil coco puffs when I opened up a donor saw's protector plate on a 372xp today. Heh heh. Never seen those before!! Hahahaha.
    Mag Craft, Horkn and M2theB like this.
  10. LordOfTheFlies
    LordOfTheFlies
    NY
    Gotcha. Wow that's weird. I guess it's cheap insurance to buy a bunch of extra filters. Which filter do you like to use? I ordered a bunch of new ones that look like this for the 372xp rebuilds.
    I like that you can open them up and clear them out without having to just replace them. Plus they have some heft to them and will help the filter follow the fuel when the tank is low.
    Horkn, John041 and M2theB like this.
  11. huskihl
    huskihl
    That’s mostly what I use. Designed by Walbro I believe. They come standard on some new Echo saws
    Horkn, John041, MAF143 and 1 other person like this.
  12. M2theB
    M2theB
    That schmootz wasn’t helping anything, but a full clean and rebuild didn’t it get it to where it should be.
    Gave up on a repair and ordered the OEM tilly HS 181C.
    Made all the difference
    here’s the aftermarket next to the tilly.
    Two things immediately
    The hole that looks like an impulse is, but isn’t, ( I guess it’s a machining aid) is much further away from the barrel. Helps eliminate air leak if the gasket isn’t right on.
    The other is the volute size and geometry. OEM is way more pronounced.
    I generally have pretty good luck with the aftermarket carbs, but not this time. Saw came to me with this am carb.
    94FF48F3-6AD6-4814-89C4-882A41C8B831.jpeg 543E9B82-CE3E-4B84-B425-0CA728D7ABE7.jpeg
  13. James Miller
    James Miller
    Hanover PA
    20211106_165602.jpg This old husky 36 followed me home yesterday. Runs but seems to leak fuel around the carb somewhere. I guess I'll start with fuel lines and go from there.
  14. The Wood Wolverine
    I blacked out a 136. Impressive they are not, but light as heck they are.
  15. James Miller
    James Miller
    Hanover PA
    This saw weighs as much as my 490 echo and gives up 15cc in displacement.
    Horkn and SKEETER McCLUSKEY like this.
  16. M2theB
    M2theB
    262XP
    Handle bar and tank are a little cattywampus like it took a good hit.
    Starts and runs.
    Has 155psi
    Leaks fuel past the tygon fuel line and cries bar oil.
  17. Czed
    Czed
    Wv
    Tore down my sister's duromax 4000
    It has less than 5 hours on it
    The exhaust valve snapped the end off
    New valves on order.
  18. Czed
    Czed
    Wv
    Someone swapped out the original wheels and tires.
    It had only been ridden a few times
    Since he bought it new
    He only rode it a few times.
    Cleaned the carb and tank
    Oil change and a new battery
    It's like new for my nieces and nephews.
  19. MAF143
    MAF143
    North Central OH
    Husky 357 getting fully torn down and all wear items replaced or dressed up. It will get a little surgery from the rotary grinder as well...
    A little wire and J-B Weld will keep the cover cracks from getting any worse. Won't be pretty, but it's a work saw, not a museum piece.
    Checking the timing and making a plan.
    Splitting the case to replace bearings and seals. Lower transfers will get matched to case halves and opened up for better flow.
    SOS Ridgerider, Czed, M2theB and 3 others like this.
  20. Czed
    Czed
    Wv
    The son read on Facebook you can
    Use 290/390 cylinders on it
    You cannot they don't fit and different impulse as well. IMG_20211130_174131.jpg
    I asked why he didn't take it to the dealer
    Here's a 046 sprocket he ran
    He obviously doesn't maintain his equipment.
    M2theB likes this.
