I can't get the 55 to run right
Discussion in 'Chainsaws and Power Equipment' started by HDRock, Aug 7, 2014.
  1. HDRock
    Ok, any thing else to prevent problems down the road ?
    Thanks , I will check and be carful .
    If the carb is messed up do you think this is really a ZAMA carb? ,http://www.ebay.com/itm/141368512366?ssPageName=STRK:MEBIDX:IT&fromMakeTrack=true
  2. Jon1270
    Jon1270
    Pittsburgh, PA
    HDRock likes this.
  3. HDRock
    Ok
    took it apart didn't really see anything wrong, impulse grommet and intake are pliable and no cracks, intake boot actually looks like new .
    The impulse grommet didn't fit real tight on the plastic tube (slid on and off real easy ) didn't seem like it would leek but IDK how tight it should be.
    Put it back together ,started 3rd pull but wouldn't idle ,adjusted it to keep it running then got out the tach, got it running good.
    WOT it's running at 11200 to 11500, idle is about 3200 lower than that it won't stay running. As far as I know it should be 2500 idle 12500 top power
    IDK maybe I just got it to far out of adjustment the other day but it was erratic now it isn't .
    All I did was take it apart and put it back together now its running good , noodled a chunk of hickory and oak .
    What do ya think is it a intermittent carb problem ?
    Took a bunch of pics here is some
    20140809_145546.jpg 20140809_152119.jpg 20140809_152128.jpg 20140809_151500.jpg 20140809_152329.jpg
    Chvymn99 likes this.
  4. HDRock
    More pics
    20140809_144633.jpg 20140809_144833.jpg 20140809_145001.jpg 20140809_145054.jpg 20140809_145135.jpg 20140809_145555.jpg
  5. clemsonfor
    So are you saying its idelimg 11500 and idle is roughly 3000 below that so its modeling 8000 rpm or so?
    If thats the case id say air leak.
    Also I have had carbs that everything looked "fine" on but were not and once rebuilt they ran fine. Usually an issue of it bogging or just not running in those cases?​
  6. HDRock
    Went out and started it back up now it's acting weird again.
    Started up idled ok punched it ,it revved real high and died now won't stay running , will start with chock closed but won't stay running :confused::confused::confused::confused::confused:
    clemsonfor likes this.
  7. MasterMech
    Fill the tank and try again.
    HDRock and clemsonfor like this.
  8. HDRock
    It's idling at 3,200, WOT is 11,500
  9. HDRock
    Oh shoot :emb: lit me go see :rofl: :lol:
  10. HDRock
    I gotta go mix some gas :D
    concretegrazer and Jon1270 like this.
  11. HDRock
    Runs much better with gas :D
  12. clemsonfor
    Was it empty or a split fuel line sucking air?
  13. HDRock
    Was out of gas .
    I know what a saw does when it's out ,just wasn't thinking of that :doh:
  14. HDRock
    I know it wasn't my imagination that it was acting up the other day but , I noodled some more hickory and it's running good :confused::confused:
  15. DexterDay
    When I put mine back together, I put some Anaerobic silicone (Dirko, CNH Gasket Maker, Yamabond, etc) Just a small amount on the inside and outside of impulse grommet, and a small amount on the inside, of both sides of the intake boot. Probably not needed when new, but an old impulse grommet that loose will cause a leak.
    With that said, it sounds like the intake partition may have been loose before disassembly? And your take down and rebuild may have snagged something up? Just a guess.. :)
    And fuel always helps a saw ;) lol Happens to everyone.
    clemsonfor, Chvymn99 and HDRock like this.
  16. HDRock
    the screws didn't seem loose but when I put it back on I pushed it in tight then tighten the screws down.
    I will order a new impulse grommet
    I don't know why it has to be running at 3200 to 3500 at idle to stay running
  17. Chvymn99
    This was a good documentation.... Thanks for the detail post....:thumbs:
    HDRock likes this.
  18. HDRock
    some of the pics I took just so I could be sure and put it back together right cuz of CRS :)
    clemsonfor, DexterDay and Chvymn99 like this.
  19. DexterDay
    Always a great idea when unsure. There is still times I take a photo. Brake bands and the arms, springs, etc confuse me still.
    clemsonfor and HDRock like this.
  20. HDRock
    Good thing I did ,had to look at a pic to get the throttle link on right
    clemsonfor and DexterDay like this.
