How to release chain brake on Husqvarna
Discussion in 'Chainsaws and Power Equipment' started by Paul Dokken, Oct 17, 2021.
Tags:
  1. Paul Dokken
    Paul Dokken
    Waxhaw NC
    I took the cover off my rancher 450 when the brake was applied. Now I cannot get it to release. How can I do this with it off the saw?
  2. Eric VW
    I had to do this for a coworker a few years ago… I chucked up the clutch cover in a bench vise with some wood scraps helping the vise to only bare on the flashed surfaces and then worked the jaws of a cheap pair of vise grips into the piece that the chain brake flag engages when mounted on the saw. Worked like a charm.
  3. M2theB
    M2theB
    Central Massachusetts
    I’ve also put it back on as far as it could go, applied pressure enough at the handle driver until I could feel engagement and used the handle as it is normally used
  4. huskihl
    huskihl
    Put the clutch cover on and push in on the top right corner. And take the brake off
  5. M2theB
    M2theB
    good idea:D
  6. Paul Dokken
    Paul Dokken
    Waxhaw NC
    The brake is engaged so there is no way to even put it back on partially.
  7. M2theB
    M2theB
    I haven’t worked on a 450, so there may be something different.
    Parts saw 350
  8. Paul Dokken
    Paul Dokken
    Waxhaw NC
    I tried that and it felt like it was moving but it didn't unlock it.
  9. hotshot
    hotshot
    USA
    Take the clutch off first.
    Jump to time 2:30 in this YT video to skip all
    of Taryls silly BS.
  10. M2theB
    M2theB
    yup, that’ll do it too.
    There’s a little more to removing the clutch than what Taryl shows though.
    you’ll need to stop the piston with a shoe string or something soft
    I made this video for a fellow hoarder just a little while ago. This 350 is coming in handy
  11. Paul Dokken
    Paul Dokken
    Waxhaw NC
    Thanks for the video link. I wasn't able to get it to reset but this one worked:
    Sean, eatonpcat, Eric VW and 3 others like this.
  12. The Wood Wolverine
    They can be a complete pain. Glad ya got it.
