Looking for Splitter Advice
Discussion in 'Chainsaws and Power Equipment' started by JeffInNH, Oct 11, 2021.
  1. Horkn
    Add a pickaroon to your arsenal and you'll speed up your process even a little more. :yes:
  2. The Wood Wolverine
    Noodle that chit in 1/4's, no more hard work.
  3. Horkn
    Yes . This is 100% correct. BTDT even on the big commercial unit that TurboDiesel is showing. I ran that exact unit at Dennis's GTG in May. I got a crotch piece of that big oak stuck on the 4 way. It needed the 2 way only to handle that, and that unit is high tonnage.
  4. Horkn
    It was actually easier and quicker to do what I did than noodle. It was ash, not elm;)
  5. Canadian border VT
    Did 4 way go all way down?? That’s a hard question to get answered
  6. T.Jeff Veal
    This is how we handle the bigger rounds on the horizontal splitter. That was some heavy 24" dia hickory.
    This is another modification we did that really helps with stringy wood.
    This is the vertical splitter with the pipe platform. That splitter is about 23 yrs old. It's slow, but gets the job done.
    See how easy the rounds slide, WeldrDave
  7. Horkn
    The 4 way got stuck. The log had to be sledge hammered off. Then the 4 way was taken off and the two way got that "round" done enough where all the crotches were split, and 4 way re installed
    Mind you that 4 way went thru all of the other crotches. Just that one piece. Noodling those old 100+ yr old tree crotches is waiting for rocks, or golf balls apparently. So most don't try that for fear of rocking a chain.
  8. The Wood Wolverine
    Weight is weight, no matter species. I don't have hydraulic help to lift, and don't hand split. Plus my saws are [​IMG]. :D Squeezing a trigger is pretty easy.
  9. Horkn
    I never had to lift these rounds. Pushed with my legs. My solution was the easiest, and no noodles to pick up from my lawn. There was enough clean up already. My dolkita was more than enough, but still the splitter was faster. I did noodle some of that big ash.
  10. T.Jeff Veal
    JK, Jason...
  11. WeldrDave
    :yes::salute: Dam right!!! :cool:
  12. WeldrDave
  13. JRHAWK9
    JRHAWK9
    Wisconsin
    You mean these? :D
    I bought the Logrite one thinking I'd be using it for just that. I just find both awkward to use while splitting having that extra item to deal with all the time.
    The Fiskars I find awesome to use in the woods when halving/quartering by hand. I use it to rotate the logs so I can split them as well as just moving rounds around.
    Horkn, T.Jeff Veal, WeldrDave and 4 others like this.
  14. LordOfTheFlies
    LordOfTheFlies
    NY
    I intially had the Fiskars but didn't like the bite. I love the handle. Got the 30" version of the logrite and love the bite but don't like the round handle as much as the contoured one of the Fiskars. But it'd be nice to have a long handled one like that to manipulate things in the truck - pushing or pulling.
    I do all my work on my driveway (99% of the time) and so I use the hookaroon to pull rounds to and up into my splitting tire to save the back a bit.
    I'll trade you that long one for the Fiskars if you are interested in that! :salute:
    Horkn, T.Jeff Veal, WeldrDave and 2 others like this.
  15. JRHAWK9
    JRHAWK9
    Wisconsin
    I agree with you. The Fiskars probably doesn't have the bite of the Logrite and I too find the round handle not as nice. I can pick up the Fiskars and know exactly which way the head is pointing and don't even have to look. Just pick up, rotate (if necessary) and swing without even looking. The thing is also light as heck.
    Kinda what I am hoping to use the longer one for. I'm sure I'll find use for it. I just got it towards the end of last winter, so I didn't have a chance to even use it much.
  16. TurboDiesel
  17. Chud
    Chud
    I got a 36” logrite last Xmas and didn’t care for it at first. Filed the spike a little and it started biting better, but still used my 18” forester pickaroon more. Now I use the logrite more than the pickaroon. I’m 6’2, so it alleviates a lot bending while moving rounds around
  18. JRHAWK9
    JRHAWK9
    Wisconsin
    At 6'5" myself that's why I like using it out in the woods moving rounds around. :)
  19. eatonpcat
    Cole (Armbru84) looked like he was in the MLB Home Run Derby beating that split off the wedge... he can swing a sledge, I would not want to see that kid angry!!
    Armbru84, Horkn, T.Jeff Veal and 2 others like this.
  20. Horkn
    Yep, got it good and stuck. That's for sure:whistle:
    eatonpcat, walt and brenndatomu like this.
