029 problem
Discussion in 'Chainsaws and Power Equipment' started by Erik B, Oct 6, 2021.
  1. Erik B
    Erik B
    Western Wisconsin
    I have an 029 Super and for the most part it has been a trouble free saw. I was out cutting yesterday and it started like normal and seemed to be fine. When I had it in the cut, it simply stopped like I had shut it off, but I didn't. I let it sit for a few minutes and tried again but it did the same thing. Any thoughts about the cuase if this? Thanks
  2. LordOfTheFlies
    LordOfTheFlies
    NY
    I think I've had that happen where the bar was dirty and a piece of crud had gotten into the sprocket and jammed it up. I think it died but now I'm second guessing myself. Does the chain move freely on the bar? Will it idle? Only in the cut? Can you rev it out of the cut? Have you cleaned the clutch area and used a flat blade to get the crud out of the bar recently?
    amateur cutter and Horkn like this.
  3. Erik B
    Erik B
    Western Wisconsin
    The engine died and the chain moved freely on the bar. I had to let it sit for a few minutes before I could get it started again. I am wondering if it could be a fuel issue.
  4. Horkn
    Probably a fuel/ carb issue.
  5. LordOfTheFlies
    LordOfTheFlies
    NY
    Could be a split fuel line. A clogged fuel filter. A fuel filter that fell off and then the line got clogged. A dirty screen on the carb. A dirty needle pin inside of the carb. Could be a dried out old black rubber diaphragm inside the carb. They should be soft and flexible, not stiff and coated with like a varnish.
    I'd check the fuel line and filter first. Open the tank and take a peek inside.
    Here's some before and after pics of the 034S carb when I got it. Very dirty.
    2021-07-18 15.05.48.jpg 2021-07-18 15.05.55.jpg 2021-07-18 15.06.10.jpg 2021-07-18 15.09.12.jpg 2021-07-18 15.09.15.jpg 2021-07-18 15.14.11.jpg
  6. brenndatomu
    That's exactly what my MS290 did when the coil was going bad.
  7. Ron T
    Ron T
    Northeast Ohio....Bowdil
    I had a 029 super that needed a coil. Acted as you describe. Oem is pricey.
  8. The Wood Wolverine
    But cheap chineseium doesn't last long at all, so in the end it pays to get the oe. I've been there, done that. In fact the cheap one made the saw feel like it didn't have near as much power, so the timing curve in it must have been wack. After OE swap, saw was a monster again.
  9. buzz-saw
    buzz-saw
    Ct.
    The two posts above would be my first thought.
    Run it and when it dies out pull the plug and check for spark while it is hot.
    Wait until it cools and then check it again.
  10. Ron T
    Ron T
    Exactly....chinese garbage was never a consideration on my end :cheers:
  11. Erik B
    Erik B
    Western Wisconsin
    My other option is buying a Stihl 362. I don't know which one would be best, M-tronic or not.
    I will check for spark when it is hot. Thanks
    amateur cutter, Ohio, Horkn and 4 others like this.
  12. brenndatomu
    I bought a used OEM for mine...about the same price as a chineez
  13. Ron T
    Ron T
    I gave Doc's 130 for a new one :eek:
  14. Ron T
    Ron T
    Might as well go with this option....
  15. brenndatomu
    :saw: pusher... ;)
  16. WeldrDave
    I love my 029 Super! I just repaired it here back a few months ago from a stripped out plug. Get it fixed Erik B , you won't regret doing it. Try fuel issues first. I had the vent tube fall off once and it started running like $#!T, check that simple little tube on the left side of the saw and see if it's missing. If it is, "There" is your problem.
  17. Horkn
    Why not just go for the ms400? Otherwise if you want to save some $ there's echo or Makita. The 362 is a great saw, but if buying new it's lost a step to other saws. Heck, there's some nice Husqvarna saws in that power to weight range that would be great. I like the makitas because most use standard 3/8 chain.
    amateur cutter and brenndatomu like this.
  18. Horkn
    I have an 029super as well. Great saw. Super reliable. But... It's heavy for what it is, and there's a lot of saws that are lighter and or more powerful.
  19. Chud
    Chud
    1 vote for buying a new saw and fixing the 029
  20. Horkn
    That's my vote too. Especially if that 029 is the only saw now.
    amateur cutter, brenndatomu and Chud like this.
