Atv’s Riding,Repairing or Racing
Discussion in 'Hobbies and Interests' started by J. Dirt, Sep 9, 2021.
  1. J. Dirt
    J. Dirt
    BB5A4D4E-E331-41D2-9A86-A600C7857E0B.jpeg 4EBF8E5C-FB43-4CE5-9F8F-71F9FE1E4ECF.jpeg 40340390-F921-478D-809B-11519CC898EF.jpeg Not sure if we have a thread yet, but I’ll throw this one here.
    Two, three, four, five, six wheels or tracks!
    Let’s see some machine pics, fun times, repairs and oops’s.
    I’ve been riding mostly three and four wheelers since I was little. I’ve gotten back to it a bit more lately when we got an 86 Honda 125 for my son to start on. It needed some odds and ends and some new rubber.
    I recently picked up a Yamaha Big Bear for myself, it needs some odds and ends too.
  2. J. Dirt
    J. Dirt
    Even made a little track out behind the house.
    Any excuse to run the tractor…… 412739B3-26AD-4F30-94C1-44718F269CC7.png 1EF00D08-D8D1-4705-AE60-9BD85ED1E271.png
  3. TurboDiesel
    Oh yeah, we like to play a little.
    Rode about 200 miles this past weekend.
  4. mat60
    mat60
    ME
    That Polaris is some nice.
    Horkn, Chvymn99, Chaz and 3 others like this.
  5. eatonpcat
    Show off! :D
  6. J. Dirt
    J. Dirt
    Any fun trails near you guys that are good riding? Not looking for big mud or anything to hairy. Just a nice cruise with some decent scenery.
    Horkn, Chvymn99, eatonpcat and 2 others like this.
  7. J. Dirt
    J. Dirt
    Tore into things yesterday. New front bearings and seals done. Found a ball joint with a bent stud so that’s on order. Opened up the clutch case. Got new secondary plate and springs coming along with primary springs. 80695393-93E1-439E-AD9E-51B8967942DE.jpeg 054627E1-0994-4C9E-BE82-987A05F0468B.jpeg 16ECAE5C-0654-450B-8376-375EE2DBA2BA.jpeg
    Got at the rear end this morning. Brakes,seals and bearings all the way across along with a new shock. 56B3BAB9-C6C1-4B93-B44C-11CB683E17A5.jpeg 3E02F818-5FA3-41FE-A2D8-01D68E9D32B6.jpeg
  8. brenndatomu
    What was the issue there? Those typically have a VERY low failure rate.
    New bearings/seals in the diff too? Those typically have a high failure rate...people just don't drain the oil after goin swampin :headbang:
    mat60, J. Dirt, eatonpcat and 2 others like this.
  9. Horkn
    Yep, got a few ATVs here. Oldest is a 91 Kawasaki bayou 300c that my buddy broke and still has not fixed( rear DS seal and bearings), a 2004 Polaris Sportsman 500ho, and we have a nearly new 2019 Yamaha Kodiak 450 up at the cottage.
    mat60, eatonpcat and brenndatomu like this.
  10. J. Dirt
    J. Dirt
    The springs in the primary seem a bit week and the plates in the secondary are a bit thin and had some of the clutch material melted near the outside edges. My guess is abuse and wrong oil being wet clutches.
    As far as the rear. The outer seals were chewed up and letting in more than they were keeping out. Luckily only the outer seals and bearings were bad. Everything internal was nice aside from the milky oil.
    mat60 and Horkn like this.
  11. brenndatomu
    Based on engagement RPM? Or maybe "dragging" at idle?
    I have seen toasted frictions caused by a little kid riding the machine...too small to shift so they would ride around in second or third gear...which is VERY hard on the centrifugal clutch when taking off from a dead stop! Good way to burn the oil and plug the filter too!
    Caught it just in time then...lucky! :yes: That doesn't happen very often.
  12. J. Dirt
    J. Dirt
    Low rpm engagement. She slams in and try’s to creep even after turning the idle speed wayyyy down.
    mat60, Horkn and brenndatomu like this.
  13. Horkn
    Gotta fix that bad habit. :hair:
    mat60, J. Dirt and brenndatomu like this.
  14. brenndatomu
    Habit? I think he is describing the problem/symptoms! :rofl: :lol:
    Horkn, mat60 and J. Dirt like this.
  15. J. Dirt
    J. Dirt
    I’ve got a heavy thumb so I’m not thinking we will have anymore low rpm engagements.:smoke:
    Broken axles and stripped gears? Mayyybe…:quad:
    Horkn, brenndatomu and mat60 like this.
  16. J. Dirt
    J. Dirt
    Well it’s alive!! Little snafu this morning. Got everything together but it would t move!! After a little thinking I pulled the side cover and looked at the clutch. I had replaced all the plates and managed to put the pressure plate on one slot off!!!! No grippy there! I moved it to the right spot lining up the tiny arrow and good to go! F1B7C87E-5591-46A1-BE0E-F4414C1BE6E1.jpeg
  17. mat60
    mat60
    ME
    Nice repair work.. Not a bad wheeler also.
    J. Dirt and Horkn like this.
  18. fuelrod
    fuelrod
    Western Maine
    Iirc you're in PA right?
    We used to go to Tower City and ride, well 2 or 3 times. It's a huge area but for some reason I remember that they started to tighten up the free for all there.
    Last trip there on of our group broke something in the first 20 minutes after a couple hour drive to get there.:eek:
  19. TurboDiesel
    Yes.
    Near Harrisburg? No wonder.
    We go to west Central and North Central pa. In the mountains. :yes:
    mat60, J. Dirt, fuelrod and 2 others like this.
  20. brenndatomu
    Kinda like the last snowmobile trip we took...was supposed to be a 2 hour ride, ended up 4 hours because we drove right into a major snowstorm...then pulled in and got stuck in the parking lot...had to unhook the trailer to dig out. Once we thought we were ready to ride, turns out that the one dude had borrowed his ride from his buddy, and it was "just serviced" at the shop, 100% ready to ride...uh, nope. Had to tear the carbs off and try to roto-root the jets out with the few basic tools we had along...this thing hadn't run in at least a year! :hair: :headbang:
    moresnow, mat60, J. Dirt and 4 others like this.
