Beginning Again
Discussion in 'The Sawyer Room' started by Cold Trigger Finger, Aug 5, 2021.
  1. Cold Trigger Finger
    Cold Trigger Finger
    Easern Central Alaska
    It is as efficient as I can get it for the amount of lumber I'm sawing. Biggest thing I wish I had for production is a twin blade edger.
    For the size logs I get here. Mostly all I need to be able to do is take the bark wane off and end up with a nice 4 sided board.
    But 5 or 6 grand is above my budget.
    This is the lumber I had on the ATV trailer.
    About 1/3rd of what I need for the Arctic Entry ( enclosed, insulated porch) . IMG_20210909_140013460.jpg
  2. buZZsaw BRAD
    When you mill are you trying to get board sizes the same as standard lumber 1x6, 1x12, 2x4 etc or whatever the log allows?
  3. Cold Trigger Finger
    Cold Trigger Finger
    I try to maximize what I can get out of the log depending on length. And of course diameter.
    When I'm working a tree up. My default bucks are 16'6" . But if there is a fairly significant grade break I will buck for the pieces of lumber that I need at that length.
    My target thickness is 1" or 7/8", for my friend I saw 2 bys at 1 5/8" thick x 5 5/8" for 2x6.
    For myself I mostly saw 1 3/4" thick for 2 by stock . For 2x4s I mill 1.75x 4" . 2x6 are 1.75x 5 5/8" . 2x8 are still 1.75 but I rough saw to 8" . X 10s I go 10"
    It seems to be that it's easier to get 2 real nice 1 5/8 x 5 5/8 out of alot of the logs I get . Than 2, 1.5x6
    I will slice 1 by boards off and not feel too bad about a bit of bark wane. I very much dislike framing with bark waney 2 by lumber. Pretty much Hate that.
    The lumber I sawed to frame the house I had a bit of bark wane in some of my lumber and it caused me grief. I have 1 dip in a butt joint of subfloor from a 2x8 I milled that had 50% wane in 1 part of the plank. I was going to scab a piece on the side of it . But when I joisted this floor I was kindof a 1 armed framer.
    So in short
    I get all the Good deminsional lumber out of a log I can , For what I'm going to be building with that lumber.
    I sawed 2, 4x10 beams for the entry . 1 is 4 5/8x 10. The other is 4 13/16 x 10.
    That is what it came out to be after I had adjusted the blade level .
