Beginning Again
Discussion in 'The Sawyer Room' started by Cold Trigger Finger, Aug 5, 2021.
  1. Cold Trigger Finger
    Cold Trigger Finger
    Easern Central Alaska
    mat60, Need2Saw, eatonpcat and 4 others like this.
  2. Cold Trigger Finger
    Cold Trigger Finger
    Went to the woods and got another trailer load of saw logs today.
    I have 11 saw logs @ the mill now. Gotta get with the program on the saw !
  3. eatonpcat
    I will agree!! Lol
  4. Cold Trigger Finger
    Cold Trigger Finger
    Took a couple pics this morning. I am liking the way I have it set up so far.
  5. Cold Trigger Finger
    Cold Trigger Finger
    I'm also going to take the axle off.
    I'm getting WAY tired of barking my shins on the hubs.
  6. amateur cutter
    Slabs are a bit in the way I would think? I assume you'll burn those in due time? Those hubs/axle hanging out there gotta be a real pain the legs I would think. If the mill's in it's long term parking I'd remove it too. Nice set up though, looks like it'll serve you well.
    mat60, JB Sawman, eatonpcat and 2 others like this.
  7. Eric VW
    yooperdave says “you’re a photographer after my own heart....”
    Nice setup Cold Trigger Finger :thumbs:
  8. yooperdave
    Well played sir....well played! :handshake:
    mat60, JB Sawman, eatonpcat and 4 others like this.
  9. Eric VW
    :salute:
    :D
    :handshake:
  10. Cold Trigger Finger
    Cold Trigger Finger
  11. eatonpcat
    Much better!! LOL
  12. Cold Trigger Finger
    Cold Trigger Finger
    Hi ho Hi Ho . It's off to the mill I go.
    It is so great having days off mid week !
    Hi Ho hi ho:salute::thumbs::saw:
    amateur cutter and mat60 like this.
  13. Cold Trigger Finger
    Cold Trigger Finger
    I gotta make more boards today . Hi Ho Hi ho
  14. Cold Trigger Finger
    Cold Trigger Finger
  15. Cold Trigger Finger
    Cold Trigger Finger
    It takes about 15 minutes for a pic to upload. So I will get more up later
  16. Cold Trigger Finger
    Cold Trigger Finger
    My friends stacks. Small but growing. 1 board at a time.
    amateur cutter, mat60 and JB Sawman like this.
  17. Cold Trigger Finger
    Cold Trigger Finger
    Ground the band blade for the first time since I started milling . It was still cutting ok but. Like a chain saw, it creeps up on ya.
    The leading side log cleanup/debarking I've been doing with my little 251 Stihl . 16" bar semi chisel , low kickback chain . Is working Great at keeping the band blade sharp on the mill. It doesn't take too long. About 5 or 6 minutes per log.
    The power feed and return is whacky for some reason. It's wide open fast on the feed. Even with the metering valve almost closed. So I push feed . Pull the slab or board, plank, timber off . Then go back to the controls and raise and return the headrig. Then drop it down for the next cut and start pushing again. It's slower than just flippin levers. But I'm a one man show so it's faster than wishing I had some lumber to build with.
    The Dremil tool tooth grinding doesn't take too long . 20 minutes or so. Maybe less. It's not as good as a nice expensive grinder setup. But it works better than many would think. As I'm not doing this for a living. Not being the peak of speed and efficiency doesn't bother me. Keeping cost down is where it's at for me.
  18. Cold Trigger Finger
    Cold Trigger Finger
    Half a load left to saw. Don't think I'll get it done today. IMG_20210909_101526459.jpg
  19. buZZsaw BRAD
    X2
  20. mat60
    mat60
    ME
