Gonna buy a Ideal Steel (I think) LOL
Discussion in 'Modern EPA Stoves and Fireplaces' started by oldspark, Aug 11, 2021.
  1. NVhunter
    NVhunter
    Northern Nevada
    I hear you with the shipping. I live in Western Nevada and it was $700 plus but a buddy also ordered one at the same time so they split the shipping and it was $400 or so each... Still expensive but manageable. I helped him move it into his house and within a year he sold his house and left the stove behind...‍♂️
    That was 6 years ago. My Ideal Steel is still good to go minus the defect that Woodstock fixed for free.
    Chaz, T.Jeff Veal and brenndatomu like this.
  2. Highbeam
    Highbeam
    I’ve moved several stoves by myself into and out of pickups and onto raised hearths. You almost never have to actually lift the stove. Besides they’re all heavy, 500-700, nobody is going to have an easy time moving it unless they work smart.
    WeldrDave, Chaz, T.Jeff Veal and 2 others like this.
  3. OhioStihl
    OhioStihl
    Southern Ohio
    That’s what I told my wife when she was upset I moved a stove by myself. It’s all about leverage and engineering. I can’t pick up that beast.
    Chaz, T.Jeff Veal, NVhunter and 2 others like this.
  4. oldspark
    oldspark
    NW Iowa
    I'm really hoping for a more even heat through the house, the Drolet did an admirable job but did not have a "low and slow" mode that i hope to have with the IS.
    papadave, Highbeam, Chaz and 2 others like this.
  5. T.Jeff Veal
    What model Drolet did you have?
    Chaz and brenndatomu like this.
  6. BCC_Burner
    BCC_Burner
    Marble, CO
    The key to even heat is air sealing and insulation, not the heat source itself.
    bushpilot, Chaz and T.Jeff Veal like this.
  7. NVhunter
    NVhunter
    Northern Nevada
    I think what this post was referring to was the stoves ability to burn at a low rate with the air intake turned down to extend the burn length vs a hot high quick output of heat which then falls quickly....
  8. oldspark
    oldspark
    NW Iowa
    The house has plenty of insulation, could be tighter as i plan on doing some sealing this fall, but too small is too small.
  9. oldspark
    oldspark
    NW Iowa
    Austral (sp?) It kicked the Summit's butt for heating.
  10. oldspark
    oldspark
    NW Iowa
    Exactly, trying to keep the temp fluctuations to a minimum.
  11. Highbeam
    Highbeam
    I used to think that but then I got a stove that could put out a steady heat to match the houses loss for 24 hours straight. Once that happens, temperatures stay even. The IS is a very controllable stove.
    Improving air sealing and insulation just make the heat loss lower which is often necessary to match your stove’s long burn setting output. If you’re blowing through 3 loads per day in any stove then you’re going to feel the temperature swings.
    Chaz, oldspark, Chvymn99 and 2 others like this.
  12. snaple4
    snaple4
    Not my thread but I’ll ask since I am moving my IS tomorrow. How do you get the stove safely off the pallet without damage stove or floor? We plan on moving the crate with the front end loader of the tractor to the house front door. From there we will set it on a floor dolly. After that I am a bit clueless…. Hopefully some responses here will help others.
    brenndatomu and Chaz like this.
  13. Highbeam
    Highbeam
    How are you getting it off of the pallet and onto the dolly? Maybe picking it with the tractor?
    Get it slid off of the dolly over onto two stacks of lumber runners that are the same height as the dolly. I usually use 2x6 lumber about 2 feet long. It's easy to slide a stove across smooth surfaces. Then rock the stove onto two legs, pull a board, rock it the other way, pull two boards, all the way to the ground.
    brenndatomu, Chaz and PA Mountain Man like this.
  14. brenndatomu
    Yup, you can do a lot with a stack of blocks and a long bar! (I have a 72" spud bar that I like to use)
    Some 1" pipes make great rollers if you need to move the stove from point A to point B in the house too (I use sch 80 PVC on tile)
    I moved a 900 lb wood furnace in, and then later on back out, totally by myself using just these tools. (and maybe a 4 wheel cart too)
    The stack of blocks and a long bar method is exactly how I got it from cart height, down onto the floor.
    Chaz and Highbeam like this.
  15. NVhunter
    NVhunter
    Northern Nevada
    These are the tools I used to get it off the pallet and then moved it into the house and in to its final resting place...
    A 1000 pound (set at 700lbs) hitch lift and a 20.5" pallet jack with 4x4s under the stove. Worked great and was pretty easy to do and maneuver. 20210423_113158.jpg 20210423_110723.jpg 20210423_113144.jpg
    Chvymn99, Chaz, oldspark and 2 others like this.
  16. oldspark
    oldspark
    NW Iowa
    I have to figure out something also, 3 point lift on tractor would work for me, would like to borrow one vs buy, rentall did not have one.
    As far as moving accross floor,the coaster things allowed me to easily move my stove accross cement floor by myself.
    Chvymn99, Chaz and Canadian border VT like this.
  17. Canadian border VT
    How we did it twice
    Put on deck no stairs strap to dolly roll it to hearth.
    Put cardboard on hearth. For adjusting to pipes..
    Granted guys who did dolly averaged 280#
  18. oldspark
    oldspark
    NW Iowa
    Been thinking about making a arm for the loader so i could put it in door but did not want to spend a lot time on something.
    Chvymn99, Chaz and brenndatomu like this.
  19. snaple4
    snaple4
    We got mine in today. Put it on the front loader to take down to house. I have 8+” walls so the stove just stuck inside the doorway (door removed). We then tipped it up and pulled it in on the wool blanket. Slid it in the rest of the way. Taking it off the wood was a challenge. Thank you for the suggestion of using stacked wood and taking one out at a time! Lots of work. Now I just need to put it together and figure out the pipe…
    papadave, Highbeam, Chvymn99 and 4 others like this.
  20. Highbeam
    Highbeam
    Holy switch box!
