Vogelzang Highlander Blower motor replacement?
Discussion in 'Modern EPA Stoves and Fireplaces' started by clemsonfor, Aug 15, 2021.
  1. clemsonfor
    Oh I forgot I got in contact with the vogelzang/USS folks. Did the chat/text feature so I didn't have to be on the phone as I did other stuff. They said I have the older model that uses the f26 blower, the one I see is f27 and like I said is not compatible. I asked if they had a part number for motors but they didn't respond with anything.
    The stove literally turned 12 years old from date of manufacture. Can't remember how long I have had it but how long do they keep parts for? I guess I would of replaced or done something before but I probably use this thing a max of 6 weekends a year so it really doesn't have that many hours on it. Looking at other stove blower motors it said ambiennt air temp of 104f. When this thing is rolling I can see the air it sucks off the floor of the fireplace being kind of warm back there. Probably not helping it.
    Horkn likes this.
  2. brenndatomu
    You might be surprised...the air through the blower is probably not as warm as you think...once it comes off the front of the stovetop however, different story.
    If you have had it all this time, and never had to fool with it before, you are doing pretty good I'd say (even with the "low hours")...the fans that we use every night for ambient noise need to be cleaned/lubed twice a year I'd say...but that is also many more hours, like every night for 8-12 hours...usually find some long blonde hairs wrapped up in them (wife and daughter) :hair:but the bearings usually are kinda dirty and very dry by then too. A quick cleaning and a drop of oil makes a HUGE difference.
    Horkn and clemsonfor like this.
  3. clemsonfor
    Pulled the bearings off. Sprayed cleaner on then, blew them. Let dry. Lightly oiled them and reassembled them. Going out to my shed to hook it to power and see if there is a difference. This was the one that barely spun when powers up before. IMG_20210816_181839073.jpg
  4. moresnow
    moresnow
    Please do tell what your go to replacement for PB is. Thanks
  5. clemsonfor
    This made no difference. Still won't start, sucks power and dims lights . Won't even start with me giving it a spin start.
  6. clemsonfor
    Most people say kroil, but it's expensive one, but if it works that's fine but my biggest bossier is that is not really available...at least stores I go too.
    Horkn, brenndatomu and moresnow like this.
  7. moresnow
    moresnow
    Can't say I've used Kroil. Don't recall even seeing it! Hmmm.
  8. clemsonfor
    The can looks like it's something straight out of the 50s or 60s.
    50/50 ATF/Acetone is a good one I have seen on YouTube and many folks who say they used it.
  9. brenndatomu
    Well that stinks...
  10. clemsonfor
    Yep. Now I'm looking for motors that I will, need to either modify the housing to accept them or cannibalize the motor or parts of it.
  11. brenndatomu
    Almost anything else...kroil is good but don't often have it around, like liquid wrench, WD-40 is always around...kinda depends what I'm trying to do, and what is handy...we occasionally get some CRC, and there is some from Permatex that is ok too...just depends on what purchasing gets a deal on sometimes too...:picard: I won't use PB unless I don't have any other choice though...can't stand the stuff.
    Horkn likes this.
  12. clemsonfor
    See I like PB better than WD. I like it cause it leaves a residue where WD dies up more.
    But when something is stuck stuck it usually takes heat no matter what.
  13. moresnow
    moresnow
    Interesting. I'd take PB far before WD as a penetrant. CRC has some good stuff. End derail.....:)
    clemsonfor and brenndatomu like this.
  14. clemsonfor
    Horkn or anyone else who knows, what would you call this style electric motor? Like (not saying this is what there referred to just making it up) if there called pancake or flat motors I'll start googling around with that name and amperage to see if that helps. I have come to the realization I'm going to have to canabalize something here.
    Horkn likes this.
  15. moresnow
    moresnow
    Take a sniff on these. I've used these 20-30 buck blowers shown on this link with success. Think retrofit!
    Amazon.com : century wood stove blower
    Edit: As a matter of fact I should grab a few more before they disappear.
  16. Horkn
    Kroil is the best. I saw that Walmart sells it now. Online only, as well as amazon. I have not seen it in any store though.
  17. Horkn
    Yep. WD is by far the worst/ least effective. But it works for some things. Liquid wrench is available pretty much everywhere.
  18. brenndatomu
    C frame motor
  19. clemsonfor
    The first 10 or so of that link are all the same basically. Unless I can take that motor out which is what I am planning on trying to do now, just want to stick with a similar RPM plus the shaft must fit my squirrel cage or new cage has to fit in existing housing. Those pictures won't work, one there is not the rear clearance and two I would need to cut a new hole in the back and weld up the old slots. I. An do that but I get back to there is not clearance in my application. I have to fit in the fireplace and sit far enough back to fit the liner to the top of stove. I already fabricated this one and cut the pedestal base it sits on so that it clears the top of the fireplace.
    moresnow likes this.
  20. clemsonfor
    Thanks. I am combing Google image search now for anything similar.
