Big Betty White
Discussion in 'Chainsaws and Power Equipment' started by GrJfer, Jul 31, 2021.
  1. GrJfer
    GrJfer
    The Woods of Arkansas
    Added new wood hauler a couple of months ago. I call her Big Betty White. 2021GMC Sierra 2500HD 6.6L gas. Looking to upgrade from a travel trailer to a 5th wheel in a year or so. Figured I make the jump now. PXL_20210728_165334220.jpg PXL_20210618_203328587.PORTRAIT.jpg PXL_20210607_003531731.jpg
  2. Backwoods Savage
    My son just bought one and took his first trip pulling a travel trailer. He loves it.
  3. WeldrDave
    Very nice!!! :yes: I have a neighbor just bought the Chevy and it looks exactly like the GMC, white , same bumpers and step side. I think his has the 6.6 gas motor in it. Beautiful...
    T.Jeff Veal, mat60, GrJfer and 6 others like this.
  4. The Wood Wolverine
  5. rdust
    rdust
    SE, Michigan
    Nice truck! I’d be curious to hear the mileage when you pull heavy.
    What size 5th are you looking at? Have you weighed the truck yet to see how much pin weight you have room for?
    WeldrDave, mat60, GrJfer and 5 others like this.
  6. GrJfer
    GrJfer
    Looking at under 30ft 10k loaded weight. Listed pin weight on the couple I have narrowed my search to have all been under 1600lb. Truck payload is 3265lbs.
    WeldrDave, mat60, eatonpcat and 4 others like this.
  7. rdust
    rdust
    SE, Michigan
    Plenty of truck for that! Nothing like watching a 2500 srw pulling a triple axle toy hauler. :jaw:
    My classic 2500hd with a duramax has lousy payload. I’m just about over with a 33’ light weight cougar loaded with the family. Full tank and family it tips at 7400lbs, 9200 GVWR…not a lot left at that point. Aftermarket brakes and a one ton spring pack make it safe but none of that matter should the law ever need to get involved. :whistle:
    WeldrDave, mat60, Ashwatcher and 4 others like this.
  8. GrJfer
    GrJfer
    Very true, and a lot of people don't think about that.
    Those older HD's are a bit limited on payload and being a diesel doesn't help. The 5vers I'm looking at are advertised as "half ton" towable. Empty may be but even that is stretching it.
  9. rdust
    rdust
    SE, Michigan
    I camp a lot and have seen my fair share of F150 eco boost trucks with max tow pulling 5vers. Most that I’ve talked to have never ran them over a scale. :confused:
    mat60, Ashwatcher, Chvymn99 and 3 others like this.
  10. GrJfer
    GrJfer
    I'd bet most if not all would be over the limit.
    mat60, Chvymn99, rdust and 2 others like this.
  11. eatonpcat
    Congrats, nice new truck!
    mat60, Chvymn99 and GrJfer like this.
  12. Jeremy Anthon
    Jeremy Anthon
    Baton Rouge, Louisiana
    Beautiful truck!
  13. Dewittmichiganwood
    Dewittmichiganwood
    I too named mine "Betty White"
    2020 ram 2500 6.4V8
    Was an upgrade from an 07 5.7V8
    Very happy with it. Impressive improvement 20200705_124417.jpg 20190719_183919.jpg 20200831_185824.jpg 20210709_161638.jpg from the previous truck. The 07 did the job, but this one even more so and so smooth.
    Also upgraded from a 25ft 5000lb. bumper pull rv to a 42ft 12,000lb. 5th wheel
    I'm getting 12.8 mpg with the new rv in tow.
    Pulls great uphill as well. Runs roughly 1800 rpm on the flats and about 2500 rpm uphill.
    3000 rpm up steep hills. Loving the 8spd transmission.
    WeldrDave, mat60, OhioStihl and 3 others like this.
  14. GrJfer
    GrJfer
    Dewittmichiganwood good looking rig. GM stuck with their tried and true 6 speed coupled to the gas engine. It shift butter smooth so far and always seems to be in the right gear. I haven't worked it to hard yet as my travel trailer is only 6000# fully loaded. I have heard other say they wish it had more gears or a lower geared final ratio, current generation is 3.73.
  15. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    GrJfer are you really going to haul wood in that pretty ride?
    WeldrDave, mat60 and Chvymn99 like this.
  16. GrJfer
    GrJfer
    Dakota Hoarder I use my utility trailer, but the truck pulls it where needed. Not to mention the trailer is much lower to the ground than Big Betty White making loading and unloading much easier.
    mat60, Horkn, Dakota Hoarder and 2 others like this.
  17. Dewittmichiganwood
    Dewittmichiganwood
    Same plan for hauling firewood. Load onto trailer.
    If not I use my little buggy/trailer for getting into the woods 20210307_122248.jpg 20201003_124349.jpg 20200222_140950.jpg
  18. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Good to hear. I’m not loading wood in Dorothy (new to me 2016 F-150) for awhile. She’s to pretty!
  19. Biddleman
    Biddleman
    River Hills of Pennsylvania
    That is sweet! :thumbs:
    Dakota Hoarder, mat60 and Chvymn99 like this.
  20. rdust
    rdust
    SE, Michigan
    That mileage is nothing short of remarkable. Most folks I talk to pulling that weight with any of the gassers get 8-9 mpg at best.
    Dakota Hoarder and mat60 like this.
