Side burner on grill won’t flame
Discussion in 'The Smokehouse' started by Sourwood, Jul 30, 2021.
  1. Sourwood
    Sourwood
    Popcorn, IN
    Okay. I ran the line on my propane grill side burner. I have flame up to the inlet for the cooking unit, but no flames out all the little holes.
    I removed the part and ran a pipe cleaner through it. Nothing stopping it up.
    There is a rotating part on the tube, that I have completely closed, fully opened, and partially opened. No flames. Rest of the burners are working fine.
    I was told this needs some me air with the fuel to burn right.
    Suggestion? I have a flat griddle made for this that I would live to cook with. Am placing the griddle on my main grill grates, but burning more fuel than necessary to fry an egg.
  2. Sourwood
    Sourwood
    Popcorn, IN
    Photo of the line and the fitting I mentioned
  3. WeldrDave
    Are you smelling any propane coming out of the side burner when you turn the nob on high? If not, There is a clog somewhere of something is capped. I once had a spider web in one of my propane gill tubes and it wouldn't light off. You are not getting any flow obviously.
    Chaz, Eric VW and PA Mountain Man like this.
  4. lukem
    Does this line have a separate pressure regulator or is the just one coming off the bottle?
    WeldrDave, Chaz and Eric VW like this.
  5. Sourwood
    Sourwood
    Popcorn, IN
    It has a separate regulator. It has flame out the end of the line over an inch long
    I ran a pipe cleaner through the tube and could see it inside the burner so no obstruction
  6. Eric VW
    Might be a PITA, but any way you can swap hoses with the main burners to see if the regulator isn’t the problem?
    Mind you I don’t know if the 2 regulators have different preset pressures, so use caution.
    eatonpcat, WeldrDave and Chaz like this.
  7. Chaz
    Chaz
    Southwestern NY
    May not be getting enough propane to support combustion at the burner unit.
    1 inch flame at the open end still seems small.
    Is the regulator adjustable?
    eatonpcat, Eric VW and WeldrDave like this.
