Stripped Screw Hole
Discussion in 'The DIY Room' started by eatonpcat, Jul 1, 2021.
  1. eatonpcat
    Replacing the Idler pulley on my dryer and it appears I over tightened the screw and apparently stripped or widened the threaded hole. Any advice?
  2. Horkn
    JB weld
    JackHammer, Screwloose, Chaz and 3 others like this.
  3. Redneck
    Redneck
    Burton mi
    X2
    Screwloose, Horkn, Chaz and 3 others like this.
  4. Eric VW
    Don’t strip your screw hole in the 1st place... :whistle:
  5. Warner
    The torque wrench is a highly underrated tool!
    Screwloose, Horkn, Chaz and 4 others like this.
  6. Eric VW
    All kidding aside eatonpcat, I don’t think you should refer to your hunny that way... oh wait- that was more kidding.
    :eek:
    Seriously meow... can you tap that hole to the next size? Real question/suggestion.
    :yes:
  7. eatonpcat
    I think the JB Weld is what I will try.
    You funny Eric!! Not sure if the location of the hole can be relocate and still activate the drum switch
  8. Eric VW
    I don’t follow.... going to the next size thread would occur in the current screw location, right...?
    IDK- am I having a wildwest moment? :whistle:
    :eek:
    Oh boy- I can see it coming....
    :heidi:
  9. wildwest
    Hey Now!! Are you asking for my frying pan splat or my :banana::banana::banana::banana::banana::banana: ?
  10. Eric VW
    Whoa... settle it sister. :rofl: :lol:
    I don’t know if I can handle yer dancin’ banana...
    o_O
  11. wildwest
    Is this better :heidi: ?
    Screwloose, Horkn, Chaz and 6 others like this.
  12. Eric VW
    Nailed it...:rofl: :lol::thumbs:
  13. brenndatomu
    My first thought too...or sometimes just going to a completely different type of thread all together will do the trick...switch from coarse to fine, or metric from sae, etc, etc...might could go to a machine thread and also put a nut on the back for reinforcement?
    On the metric/sae thing, sometime the next size metric will be about a 1/2 size bigger and go right in, especially on those self tappers in sheet metal.
    Oh, and one other trick I've done is to get a rivet-nut...nut-sert...what ever you want to call it...drill the hole out, insert the nut, use a bolt/washer/nut to crimp it in place, install new bolt/pulley.
    Pic of what I am talking about...
    [​IMG] Before
    [​IMG] After
  14. eatonpcat
    Whoops, must have been the Blue Smoothies...I thought you said to drill a new hole, not Upsize the hole
    Screwloose, Softwood, Horkn and 3 others like this.
  15. Semipro
    Semipro
    SW Virginia
    I've inserted an appropriately-sized piece of a zip tie into stripped holes and then inserted the screw with some success. I think that's a long shot here though.
    It looks like you might also be able to insert another piece of metal behind the stripped hole. The metal strip would have a hole in it and would need to be longer to allow you to keep it from turning while tightening the screw.
    You could also drill a hole next to the stripped hole and install a u-nut like the one below.
    Screwloose, Horkn, eatonpcat and 2 others like this.
  16. Scotty Overkill
    Heli-coil for the win....
  17. TurboDiesel
    Call a QUALIFIED repairman? :whistle:
    :p
    J/k
    I'd probably try drilling and tapping for a machine bolt. Say, 1/4-20 or some other "standard size". A little blue lock tight to keep things together...
    :handshake:
    Good luck brother!
  18. don2222
    don2222
    Salem NH
    Wow, I never heard of these before!
    That is good info and Harbor Freightie has a nice kit!
    Threaded Insert Riveter Kit
    Screwloose, Chaz, eatonpcat and 2 others like this.
  19. don2222
    don2222
    Salem NH
    Looks like a very good option from Au
    Looks like a very good option from Autozone
  20. brenndatomu
    They work great (the nut-serts...I'm not familiar with the HF kit) especially if you need to put machine threads on the back side of a blind panel, or just don't want to fool with a separate nut on the back side...
    Screwloose, Chaz, Horkn and 2 others like this.
